4bbl intake swap
Old Jan 18, 2016 | 07:33 PM
andrew's64's Avatar
andrew's64
4bbl intake swap
I just did a 4bbl intake swap and a new hooley 600. Not really satisfied and cant tell much difference. I swapped the 2bbl intake out with a 390 S code intake. Couldn't really figure out the kick down so i left it unhooked. The holley has the spot for the kick down. Shpuld i go back to the 2bbl? Or should i try a ford 4bbl carb? Whats anyones thoughts? I paid $100 for the intake.
Old Jan 18, 2016 | 07:58 PM
351Cleveland C4's Avatar
351Cleveland C4
You swapped from a 2 barrel to a 4 barrel almost twice as big and you can't tell a difference?!?!? Something's wrong....
Old Jan 18, 2016 | 08:24 PM
HIO Silver's Avatar
HIO Silver
Your intake and 4V carb swap is not yet complete. 'Can't really tell what performance it has yielded until it is.
Btw, what exhaust configuration is currently installed?
Old Jan 18, 2016 | 08:50 PM
andrew's64's Avatar
andrew's64
its got dual exhaust. stock manifolds and dual glass packs. yeah theres something id say to. usually you can tell a big difference in 2 to 4bbl swap. I cant figure out what would be wrong though. im gonna put headers later down the road.
Old Jan 18, 2016 | 09:00 PM
HIO Silver's Avatar
HIO Silver
As configured, you're asking a sumo wrestler to breathe through a straw. When upgrading, improving the exhaust on FE engine is always the first step due to their restrictive exhaust manifolds. Only after are intake improvements worth the effort.
Install the headers and you will be amazed at the gain in HP and TQ. ... A gain of 30 to 40 HP would not be unrealistic as a 4V combination.
Meanwhile, hook up the kickdown and then test/tune.
Old Jan 18, 2016 | 09:16 PM
andrew's64's Avatar
andrew's64
ok well I have a 4bbl on my 73 360 and it performs real well and its stock with single exhaust. the carb on it is junk too lol. im gonna put headers on both of them. anyways the stock kick down leaver I cant seem to get it hooked up to the holley correctly. its like I need a different one or something. like it doesn't reach like it supposed when the 2bbl was on it.
Old Jan 18, 2016 | 09:28 PM
HIO Silver's Avatar
HIO Silver
Ta-dah. ... It requires additional parts.
Read up: https://www.ford-trucks.com/forums/1...own-setup.html
Old Jan 18, 2016 | 09:33 PM
andrew's64's Avatar
andrew's64
So I need to find another kick down rod for the transmission? The holley carb has the spot/leaver to hook the kick down up. will the truck perform better with the kick down hooked up? Also I forgot to mention the truck isn't running as good as I think it should. I think im gonna swap out the point for electronic ignition.
Old Jan 18, 2016 | 09:35 PM
andrew's64's Avatar
andrew's64
I don't get why the 73 would run better when the carb is all wore out and the other carb is brand new. 73 is also stick
Old Jan 18, 2016 | 09:38 PM
HIO Silver's Avatar
HIO Silver
No. Didn't you click on the hyperlink and see the PN on that thread? READ.
Old Jan 18, 2016 | 09:42 PM
andrew's64's Avatar
andrew's64
Ah no I didn't click the second link. sorry so I need to get that extension for it to work?
Old Jan 18, 2016 | 09:44 PM
andrew's64's Avatar
andrew's64
also I need to figure out where to hook the spring to for the kick down leaver. it doesn't have a spot. is there another bracket I need?
Old Jan 19, 2016 | 02:30 AM
willowbilly3's Avatar
willowbilly3
Did you do a compression check or put a vacuum gauge on it before you started to see if it was healthy or in good tune?
Old Jan 19, 2016 | 03:58 AM
andrew's64's Avatar
andrew's64
Negative. truck ran pretty good before I did the swap. the old guy I got it from kept it running good.
Old Jan 19, 2016 | 09:44 AM
MIKES 68 F100's Avatar
MIKES 68 F100
lokar makes a Kickdown cable kit , much easier than trying to get stock rods lined up.
I have one , very easy to hook up .
