choke pull off adjustment
Old Jan 17, 2016 | 09:35 AM
reno138's Avatar
reno138
1987 f-150 351, Had choke pull off adjusted to open 7/32 when the temp were in the 30,s. Last night went down to 14. Choke did not pull off at all. Do I need to adjust choke to have less tension or readjust the pull off. By the way the pull off is the piston type on a Holley. With electric choke.
Old Jan 20, 2016 | 04:57 AM
claydbal's Avatar
claydbal
the pulloff should overcome spring tension, unless you have the spring really tight. i would back off the spring first, the recheck pulloff.
Aynor90
Mar 2, 2015 10:27 AM
bryan_johnson
May 12, 2006 11:54 PM
SOCOM
Jun 27, 2004 07:53 PM
tamarackstyle
1978 - 1996 Big Bronco
Dec 2, 2001 03:26 PM
