Choke spring?
Old Jun 27, 2004 | 01:16 PM
SOCOM's Avatar
SOCOM
Angry Choke spring?
Hi guys.
I have an 86 f150, 300-6 with the original carter 1bbl carb. I've been having problems with the automatic choke. I've adjusted it cold to where it's closed on startup. However, after the engine's warm, I'll slow down to a stop and the engine will run rough, rich, and eventually flood itself out. After that I've got to turn the choke to open (it's still closed on a hot engine) in order to get it to start once again. That wasn't fun on that hot iron without a pair of gloves.
So I'm coming to the experts, what could be wrong with my choke? I want to say it's the spring inside the choke actuator since I believe that as the engine warms up, so does that spring and it opens the choke up. But I'm also a carb idiot, being a kid having grown up on the wonders of fuel injection. So I'm open to suggestions. Ask me if you want me to check anything. Right now I've just got that choke open and it takes forever to start it up, plus all the problems that come with leaving that little guy hanging.
So I'll take all ideas and don't be afraid to ask if you need any more info.
Thanks,
Greg
Old Jun 27, 2004 | 01:55 PM
87 XLT's Avatar
87 XLT
Many moons ago when my 67 Dart wouldnt start because of a stuck automatic choke I simply replaced it with a manual choke kit from Pep Boys. Problem solved.
Old Jun 27, 2004 | 04:22 PM
LxMan1's Avatar
LxMan1
Could be a bad spring. Is it an electric choke or hot air.
Old Jun 27, 2004 | 04:32 PM
SOCOM's Avatar
SOCOM
It's an electric choke.
Old Jun 27, 2004 | 07:53 PM
fmc400's Avatar
fmc400
MSEE
It could be set too tight. You do want tension in it in the morning, but not so much that it can never open. You could lean it out little by little...lean it a notch, live with it for the day, if it's no good, try again the next morning. A good way to set your choke is in the morning (when the motor's cold), rotate it rich until the choke is closed tight, then lean until the plate barely opens, then rich again til it pops shut. Also verify you have proper pulldown clearance.
Hopefully you just need to lean the choke a bit. In my opinion new springs are overpriced.
fmc400
55
Jul 30, 2014 10:11 AM
Rusty_S
Dec 12, 2012 02:24 PM
ctubutis
'80-'86 FAQs (Frequently Asked Questions)
Mar 30, 2011 08:20 PM
gearshift101
Nov 29, 2004 08:22 AM
blueBlooded
Oct 23, 2003 11:49 AM
