Overheating when sitting still
Old May 3, 2016 | 11:09 AM
87crewdually's Avatar
87crewdually
The rear HVAC system is behind the panel in the very back on the right.
Old May 3, 2016 | 11:21 AM
Totally Tuna's Avatar
Totally Tuna
Are your meaning the engine compartment, or rear of the vehicle. Excuse my ignorance.
Old May 3, 2016 | 11:23 AM
87crewdually
Through the barn doors at the back bumper.
POST #24 for pics
post 24 for rear HVAC PICS
Old May 3, 2016 | 11:40 AM
Totally Tuna
Thanks for the link to the pictures. I would have never found that on my own.
Old May 3, 2016 | 11:42 AM
Totally Tuna
I will still have to be able to positively identify where the problem source is, but I'm suspecting the front heater core now as the times I was smelling antifreeze it was coming from the front, but I couldn't find any leaks.
Old May 3, 2016 | 09:38 PM
Misky6.0's Avatar
Misky6.0
The Ex has a single a/c compressor even with dual front/rear heat/a/c.
There is a special vacuum actuated valve on the heater hose (right next to a/c compressor up top). In MAX a/c mode this valve blocks hot water from reaching the heater cores, thus increasing the cooling effectiveness since the heater isn't as hot.
Water pump impeller, (intermittent) frozen a/c compressor, faulty wire to fan could all cause overheating... but an intermittent problem is tougher.
Old May 3, 2016 | 10:58 PM
Totally Tuna
I was just watching a Youtube video about the vacuum system and one common almost common denominator is engaging 4wheel drive. I don't remember ever engaging 4 wheel drive on Friday, but most definitely in CO and on Saturday. I will try this out tomorrow while driving around town. I know the vacuum system controls the heater valve, but how would this cause the truck temps to rise. I get how it would mess up the A/C and heat, but not how it would effect engine coolant temps upward
Old May 3, 2016 | 11:13 PM
Yahiko's Avatar
Yahiko
Here is the retail guide.
Once you know where you need me to look I can post more info.
Sean <BR>
6.0L Tech Folder
Blknght22571
15
Jul 5, 2024 08:33 AM
microbc
Jun 20, 2015 01:45 PM
vamstad
Escape & Escape Hybrid
Apr 19, 2011 04:31 PM
mattd17
2004 - 2008 F150
Jul 31, 2008 03:03 PM
ET1
1997 - 2003 F150
May 18, 2005 08:30 PM
