get this, notch the ZF5 tail end of trans for 205 to bolt up, measure correct driveshaft length, may need to get old ones rebuilt to fit, may not. May have some trickery to bolt onto cross member. Its a swap I may pursue
As for the horn, mine doesn't work. Being a MASHOLE native I just use the lucky finger or highbeams or left/middle pedal to get the point across.
Ooooh, that adapter is PURDY... All I need is $300 for that, $1300 for a ZF5 and a bunch of time. Sure wish it was a feasible thing to do.
My horn doesn't work, but shouting and revving my motor works just as well, especially if the offending idiot is behind you.
