horn wont work
Old Jan 13, 2016 | 05:47 PM
oleblue1977's Avatar
oleblue1977
horn wont work
I have a 1977 f150, horn wont work,,,,changed relay, when you honk horn the relay makes a twang sound....any thoughts???
Old Jan 13, 2016 | 05:57 PM
mountain dewd's Avatar
mountain dewd
Is the *horn* (noise maker) itself broken? How are your wires?
Old Jan 13, 2016 | 06:17 PM
oleblue1977
that is next thought.....just how do you test a horn?
Old Jan 13, 2016 | 06:18 PM
mountain dewd
Reckon you could just hit the 2 wires to a 12V battery and see if it lights off.
Old Jan 13, 2016 | 06:21 PM
oleblue1977
with power to the relay.....not alot of other options but the horn itself and the wire to horn,.....correct?
Old Jan 13, 2016 | 06:22 PM
mountain dewd
I believe so. Mine was never hooked up properly, so I am only assuming.
Old Jan 13, 2016 | 06:24 PM
oleblue1977
u see a big difference between your edelbrock and standard carb?
Old Jan 13, 2016 | 06:27 PM
mountain dewd
I bought the truck with the 650, so I do not have much of a baseline to compare with, but I like the carb and the truck has plenty of power and runs well. 10-12 mpg is possible. Might be a wee bit big, but I am overall pretty pleased with it.
Old Jan 13, 2016 | 06:30 PM
oleblue1977
you got an overdrive on the transmission?
Old Jan 13, 2016 | 06:31 PM
mountain dewd
No, just a stock NP435 and a very light foot.
Old Jan 13, 2016 | 06:33 PM
oleblue1977
i wanna put an 80s overdrive trans in my 1977....try to get a little better mileage....didnt know if u had any experience with it
Old Jan 13, 2016 | 06:41 PM
mountain dewd
Wish I had an OD, but there's almost nothing out there for an FE block, and a Gear Vendors OD is $3000. If you have a 351/400, I think a ZF5 will bolt right on up. The gear spacing will be better, plus the OD and will really wake your truck up. That is, if you want to go manual. I think an OD auto could work too though.
Old Jan 14, 2016 | 02:55 PM
jbehuniak's Avatar
jbehuniak
ZF5 adapter kit
get this, notch the ZF5 tail end of trans for 205 to bolt up, measure correct driveshaft length, may need to get old ones rebuilt to fit, may not. May have some trickery to bolt onto cross member. Its a swap I may pursue
As for the horn, mine doesn't work. Being a MASHOLE native I just use the lucky finger or highbeams or left/middle pedal to get the point across.
Old Jan 14, 2016 | 03:26 PM
brian1080's Avatar
brian1080
I've had horns do that when they get water in them, might check for that.
Old Jan 14, 2016 | 04:11 PM
79F150400M's Avatar
79F150400M
Horn broke.....watch for finger! LOL
