Windshield Washer Freeze
Old Dec 24, 2016 | 10:41 AM
  #61
Tedster9's Avatar
Tedster9
A glug or two of 90% Isopropyl should help with that. Inveterate cheapskates make their own, I guess, with Ammonia, dishsoap and alcohol.
Old Dec 24, 2016 | 11:12 AM
  #62
rmccbride's Avatar
rmccbride
Originally Posted by elemint
Cheap ww fluid does not have enough alcohol in it.
While true... this is not the problem 99.9% of the time on these trucks..
Old Dec 24, 2016 | 01:03 PM
  #63
Jus Cruisin's Avatar
Jus Cruisin
I was in Michigan for nearly two weeks and my washer fluid sprayers were inoperable the entire time. They didn't thaw until I got into North Carolina coming home. I won't have the truck up there in the winter ever again so I'm not going to mess with it.
Old Dec 29, 2016 | 02:37 PM
  #64
Big-Red-Lariat's Avatar
Big-Red-Lariat
We can get to -30 in Canada quite often, so the trick is during the coldest months (now) add a cup of methyl hydrate to the washer reservoir and pump it well into the lines for a minute or so and it will never freeze up again. Cheap fix found in the paint section of any hardware store...they use it for cleaning shellac brushes, and no it won't hurt your truck paint.
Old Dec 29, 2016 | 05:38 PM
  #65
pikapp's Avatar
pikapp
Interesting. I looked up methyl hydrate, to see what it was and was also directed to some HEET information. Read that the Heet Yellow, being 99% methanol, can be used in windshield washer fluid reservoirs to deter ice buildup. Never knew that.
Old Jan 2, 2017 | 02:59 AM
  #66
90trunk's Avatar
90trunk
My '16 SCREW has a 05-2016 assembly date. The valve in the cowl was a three way "Tee" or "Wye" design, not a straight nipple configuration. If this is the "fix" used by TSB 16-0082, it didn't work in my truck in moderate 20*F weather. FWIW, the truck was full of Rain-X fluid and it was dosed with isopropyl alcohol. This isn't a washer fluid freezing issue, it is a check valve binding in cold weather issue.
When I decided to remedy this situation the check valve was again stuck closed and it was 8*F in the driveway. The plan was to drill the valve, but plastic is hard and brittle in the cold. I ended up replacing the check valve with a plastic vacuum T fitting. It still seemed easier to fix it myself than to go to the dealer.
We shouldn't have to do stuff like this to a new truck...
Old Jan 2, 2017 | 07:43 AM
  #67
T diesel's Avatar
T diesel
How the hell can anyone consider blaming the fluid!
PLEASE!
It's a design issue.
Old Jan 2, 2017 | 11:08 AM
  #68
90trunk's Avatar
90trunk
A couple of images of the 05-2016 assembly check valve.
Old Jan 10, 2017 | 08:32 AM
  #69
Evelina Burgess's Avatar
Evelina Burgess
I have a 2016 Ford F-150 in the Washington DC area. I have the same exact problem. After driving for over an hour, I went to turn on the windshield washer and it wouldn't come on. After a near accident due to poor visibility, I stopped and checked only to find the fluid frozen..it was 10 degrees, the fluid we had in there was -25degrees. It is definitely a defect. Of course I took it in to the dealership and they found nothing wrong with it. But I am reporting this issue.
Old Jan 10, 2017 | 11:38 AM
  #70
rmccbride's Avatar
rmccbride
What brand of fluid were you using that froze in the tank? This is unusual as most often it's rain water that has gotten into the top of the check valve that freezes stopping the valve from opening..
Old Jan 10, 2017 | 12:13 PM
  #71
Evelina Burgess
The fluid that was in there was from the Ford dealership where the truck is regularly serviced. I was truly surprised when I looked on their repair work order to find that they recommend that I use a different type of fluid from what they put in my truck. I took a picture when I found the fluid compartment frozen. It is an absolute safety hazard. When temps drop, the washer fluid tank should not freeze and remain frozen even when the vehicle has been running for over an hour. With snow and mist hitting the windshield and then drying, My visibility was completely non existent in the middle of busy traffic where I had to drive by looking out of the side windows until I could safely stop somewhere. I also own a Honda and a Dodge...never had any issue like this before.
Old Jan 10, 2017 | 12:47 PM
  #72
rmccbride's Avatar
rmccbride
This is beyond just stupid,,, on your dealers part.. makes one wonder what kind of cheap oil they are using.. if they are actually changing it at all and not just wiping the filter clean.
Old Jan 10, 2017 | 01:29 PM
  #73
JKBrad's Avatar
JKBrad
It actually got down to 18 here for a couple of mornings last week. I use the green Prestone washer fluid and had no problems.
Old Jan 10, 2017 | 02:59 PM
  #74
pikapp's Avatar
pikapp
Ditto. Flushed out the Rain-X fluid, put in fresh Prestone, good for -27, past week we've been single digits, no issues.
Old Jan 11, 2017 | 04:55 AM
  #75
rmccbride's Avatar
rmccbride
What color was the rain-X?
