Windshield Washer Freeze
Old Feb 3, 2016 | 06:49 PM
  #46
ssandirene's Avatar
ssandirene
Another spin on this problem, if you have washers that freeze.
Where was your truck built?
If most are coming from one factory,then we have a supplier problem.
Old Feb 3, 2016 | 08:08 PM
  #47
GlueGuy's Avatar
GlueGuy
Only slightly off-topic here. I did have one instance of the driver-side window deciding not to roll down after a freezing rain. I tried it a couple of times, and decided that it must be frozen. When it warmed up the next day, I gave it a little "help" with my hand, and it came down & has been working fine ever since.
Thankfully, we don't get a lot of below freezing temps around here, so who knows if I ever see it again.
Old Feb 5, 2016 | 12:31 AM
  #48
Iowna Ford's Avatar
Iowna Ford
Originally Posted by rmccbride
It worked on his truck because the sun had warmed up the cowl and it warmed up the check valve. In your truck while driving the air cooled everything off and check valve stuck again.. As far as the nozzles why are everyone's both stopping at exactly the same time,, odds are one would stop before the other even if only by a few seconds, making it look more like the check valve stops opening at a certain temperature.
Your logic is 100% correct. I totally agree! That is EXACTLY what I asked the shop manager. He agrees with us too, but Ford says "the valve" is not the problem, so his hands are tied.
Old Feb 5, 2016 | 12:47 AM
  #49
Iowna Ford's Avatar
Iowna Ford
Can I get some pictures, please?
My new "washer assembly" was installed today. Included the cowl piece, both washers, all lines, and "the valve".
I think the sprayers look slightly different. The cowl also appears slightly different...specifically, the holes/grille.
I didn't take any pictures of the old pieces. It was dark and I was in a hurry when I picked up my truck. I didn't even look at it until I got home.
I would be extremely grateful if someone would post a picture of their sprayers and cowl...just a quick one, from the outside. So I can compare.
Thanks!!!
Old Feb 5, 2016 | 12:50 AM
  #50
Iowna Ford's Avatar
Iowna Ford
P.S. Ford is indicating that aerodynamics are playing a part in this mystery. I don't really buy it, but I thought I would share information.
Old Feb 5, 2016 | 12:55 AM
  #51
Iowna Ford's Avatar
Iowna Ford
That's pretty normal where I live. Toronto, Canada. I have that problem on a regular basis...usually just as I'm about to order at a drive up. Then I'm sitting there with my door open lol.
I wouldn't worry about it. : )
Old Feb 5, 2016 | 10:04 AM
  #52
rmccbride's Avatar
rmccbride
That is why they don't spray very high on the windshield on the highway and why I used a needle to change the aiming and stream pattern of them. But until I removed the check valve they didn't work when cold out.
Can someone with a 2014 or older tell me if the nozzles are located in the cowl or in the hood?
Old Feb 11, 2016 | 11:46 AM
  #53
Headric's Avatar
Headric
I'm having the same issue everyone else is describing. Have had my truck to the dealer 3 times with no resolution.
I see the check valve as a likely culprit, just wondering what work people have had done with guaranteed success so I can go back to the dealer with options...
Old Feb 11, 2016 | 12:00 PM
  #54
rmccbride's Avatar
rmccbride
Just remove the check valve and replace it with a straight through nipple or piece of metal tubing. Or run a 1/8" drill bit through the check valve.
Old Dec 19, 2016 | 10:26 PM
  #55
jake00's Avatar
jake00
Just did a 700 mile trip over a few days, had the same issue, good fluid, appears to be froze/clogged. Where's the check valve located?
Old Dec 20, 2016 | 05:44 AM
  #56
Fmc4lfe's Avatar
Fmc4lfe
Never had this problem ever
Old Dec 20, 2016 | 06:31 AM
  #57
Headric's Avatar
Headric
Just to follow up on this old thread, there is now a TSB out for this issue. I'll see if I can dig up the number, or it might be located on the stickied posts on the front page of the forum.
I took my truck in, told the dealer specifically which TSB it was related too and have since not had any problems.
Was -15 Degrees Celsius (-22 Wind Chill) this morning and working fine.
Old Dec 20, 2016 | 06:35 AM
  #58
Headric's Avatar
Headric
Here's the TSB.
http://m.ford.oemdtc.com/TSB/16-0082.pdf
Old Dec 21, 2016 | 09:07 PM
  #59
seventyseven250's Avatar
seventyseven250
Thanks for posting the TSB.
Old Dec 24, 2016 | 10:24 AM
  #60
elemint's Avatar
elemint
Cheap ww fluid does not have enough alcohol in it.
