Frame eng. mounts?
Old Jan 11, 2016 | 07:43 PM
ozblitz's Avatar
ozblitz
Frame eng. mounts?
Can the frame mounts for a 240 eng. be used if you're sawping a 5.0? Or do I need to get the frame mounts specific for a small block?
Thanks for your help guys.
Old Jan 11, 2016 | 09:29 PM
Randle's Avatar
Randle
Your 240 mounts are 1" taller then 302 mounts. You would need mounts from a 302 or a 73-79 truck with a 351M or 400.
Old Jan 11, 2016 | 11:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Randle
Your 240 mounts are 1" taller then 302 mounts. You would need mounts from a 1969/79 F100/150 302 or a 77-79 F100/350 2WD with a 351M or 400.
351M/400 introduced in 1977.
Old Jan 12, 2016 | 05:54 AM
willowbilly3's Avatar
willowbilly3
I think I have a set of the 302 mounts. PM me if interested
Old Jan 12, 2016 | 09:03 AM
Randle's Avatar
Randle
Thanks ND, Somebody has to keep me lined out. Basicly any Bump or Dent with a 302, 351M or 400. After 45 years a lot of swaps have been made.
Old Jan 12, 2016 | 02:45 PM
ozblitz's Avatar
ozblitz
So the 1" height difference really that critical? Just thinking about it being a small block, I figure if 351/400 is same frame mount wouldn't that eng. be taller than 5.0?
Old Jan 12, 2016 | 03:25 PM
ultraranger's Avatar
ultraranger
The 302 perches not only are shorter than the six cylinder/FE perches, they also move the 302 back towards the firewall.
You can get the 302 perches from any '69-1/2 through 1979 donor truck that came with a 302.
If your truck is a pre-'69-1/2 model, you'll have to drill two additional holes (per side) in the crossmember to bolt down the lower ends of the 302 perches.
Old Jan 12, 2016 | 08:12 PM
ozblitz's Avatar
ozblitz
Thanks Ultra. My frame is a 67. Any pics or measurements as where to drill the holes?
Old Jan 12, 2016 | 09:20 PM
ultraranger
Comparison Photos of Engine Perches - FORDification.com
Old Jan 12, 2016 | 09:43 PM
ozblitz's Avatar
ozblitz
Man, I had no idea those photos were in that site! Thanks.
Old Jan 13, 2016 | 02:55 PM
NumberDummy
Same as 1977/79 F100/350 351M/400 2WD
1yamman350
Dec 3, 2007 09:06 AM
Bill W
Jan 26, 2007 08:23 AM
Polkat
Feb 23, 2004 09:29 PM
wolverineflight31
Jun 27, 2003 06:37 AM
jwtaylor
Sep 20, 2002 01:50 PM
