400 motor mounts
Old Feb 23, 2004 | 07:30 PM
Polkat's Avatar
Polkat
400 motor mounts
As seen elsewhere, I'm dropping a 400 into a '73 F-100 that presently has a 302. I'm concerned about what I'll need for front motor mounts/brackets. I know that it won't just drop onto the 302's mounts/brackets (or will it?), so what will I need?
Old Feb 23, 2004 | 07:38 PM
CJJTulsa's Avatar
CJJTulsa
Nope, 302 mounts won't work, and you'll have to either use a different tranny or change bellhousings if you have a C4 or stick. Not sure, but it looks to me like the mounts from an early 80s F Series with the 351M/400 might work. They use the stud type mount (providing the perches in your truck use the stud type mount, and I think they do). If you can find a set in the boneyard you can use for a mock-up, that might be worth a shot.
Old Feb 23, 2004 | 09:29 PM
ecarter50's Avatar
ecarter50
302 frame brackets will work. Use 78/79 rubber mounts for 351m/400.
