289/302 same motor mounts as 351m400
i am building a 289 engine for my 66 mustang, and was wanting to build a test stand to test run it on before installing it in the car. i decided against it because i didnt have time to fab something up. now a buddy of mine says he has a older ford truck frame. this truck previously had a 351m and im thinking it was a 77 or so year truck. my question is can i set my 289 down in its motor mounts instead of builidng a test stand or are the mounts different? if it would bolt up, it would save me a ton of fabrication. thanks for any help
Originally Posted by 51dueller
you will have to get the 302 truck engine mounts for it to fit as the 351M/400 ones are different.
D7TZ-6028-B .. Right Engine Mount Perch
D7TZ-6029-B .. Left Engine Mount Perch
Fits: 1973/79 F100/350 302 & 1977/79 F100/350 351M/400 2WD.
Originally Posted by 1yamman350
so the engine mounts that came off my car will bolt up to the truck frame?
If the truck frame had a 351M or 400 engine, the engine stands are the same as a 302. You will need rubber mounts to fit to those stands to hold your 289 engine. A 302 engine is the same family as a 289.
small.block.ford.guy
03-08-2014 04:25 AM
65fordguy
10-19-2007 10:18 PM
restoringmy46
10-04-2006 09:23 AM
