Sponsored by: Real Truck
Mystery Can
Old Jan 11, 2016 | 10:51 AM
agpopp's Avatar
agpopp
Mystery Can
On my '08 V10 Auto, there is what looks to be some type of exchanger mounted to the front lower portion of the trans. It is black, round and has the 2 front trans cooler lines going into the right side, and the 2 rear lines going to the left. Can't find it listed on Tasca parts or anywhere for that matter. Is this a filter? An exchanger? A cooler? Is it a wear item? Lifetime?
I'll get a pic if need be.
Thanks
Old Jan 11, 2016 | 11:05 AM
ligito's Avatar
ligito
Sounds like a transmission fluid cooler.
Old Jan 12, 2016 | 07:53 PM
speakerfritz's Avatar
speakerfritz
I had an 08 f-350 and I change that item once....its a bypass transmission filter. its called a bypass becuase you can see thru both of the pathways and the way it works is a small percentage of the fluid goes thru the element rather than all of it like most serial filters. it is a PIA to change becuase the fittings are difficult to work with.
Macs1964F100
Jul 23, 2014 01:39 AM
KenRebF-250
Aug 1, 2012 11:48 AM
labman1014
Sep 1, 2011 05:47 PM
yz400f
Apr 17, 2009 12:02 PM
wickymustang
Escape & Escape Hybrid
Apr 7, 2009 04:21 PM
