Sponsored by: Real Truck
2000 F550
Old Jan 10, 2016 | 02:44 PM
J1977's Avatar
J1977
2000 F550
I'm working on a 2000 7.3 that was running but had no power so we changed out all the injectors and glow plugs and rebuilt the turbo now there is no start I can use some help here thanks in advance.
Old Jan 10, 2016 | 06:38 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You might have better luck getting an answer by having this moved to the 99.5-03 7.3 forum by a moderator.
By "no start" do you mean that you are getting nothing at all when turning the key or the starter is cranking the engine but it is not starting? Checked to make sure you did not accidentally unplug the big connector on the drivers side valve cover? What about the WTS light, is it coming on when you turn the key to the on position? Are batteries good and charged fully? Is there oil on the dipstick? If it was running before you rebuilt the turbo then there is something that was bumped or knocked out of whack causing the truck to not start now.
Old Jan 10, 2016 | 07:43 PM
J1977's Avatar
J1977
The wts light works properly and oil level is fine it's turning over good I think it may not be getting enough voltage and the rpm is to low to fire up and We're getting black smoke from tail pipe so what do you think about that?
J1977
Jan 11, 2016 07:32 PM
briancbk
Sep 11, 2011 10:26 PM
amaftr
15
Jul 15, 2011 01:10 PM
billcollector
30
Dec 31, 2009 09:48 PM
TheycallmeNASty
Dec 5, 2006 10:29 AM
