Unforseen issues in engine swap?
Old Jan 10, 2016 | 12:47 PM
chaindrive75's Avatar
chaindrive75
My work vehicle is a '90 E-150 4x conversion. It still has the factory 302 FI and AOD. At 295k this thing is tired and can't get out of it's own way! Thinking about swapping to fresh 351 w/ C6 out of an '85 Bronco. Will the injection manifold bolt to the 351 heads? Will there be a problem with a change of trannys? Not sure if this is an EAOD. TIA
Old Jan 10, 2016 | 02:28 PM
blageurt's Avatar
blageurt
Is the E40D what you have now ? If yes, you need the PCM ....The C6 does not need a Computer...It is Hydraulic....
As far as the manifold goes I think it might ...Check this :Free Shipping on Orders Over $99 at Summit Racing
Other questions let me now
Old Jan 10, 2016 | 03:54 PM
fordman75's Avatar
fordman75
The 351W has a different lower intake then the 302. The 351W has a taller deck so the lower intake is wider. So the 302 lower intake won't fit on the 351W.
If it has a E4OD it will have a push button either on the shift **** or on the dash. The AOD won't. If you have the E4OD it's computer controlled. The AOD and C6 aren't. And the different transmissions might be different lengths. So that may require relocating the transmission crossmember.
Old Jan 10, 2016 | 04:11 PM
blageurt's Avatar
blageurt
I did not know that about the 351W and 302...I only had Clevelands , 351M's and 460's...good point fordman....
Old Jan 10, 2016 | 07:03 PM
Conanski's Avatar
Conanski
If you want the new motor to be EFI you need a complete 5.8 intake system(upper and lower), and a 5.8 distributor as the 5.0 version won't work in the larger block. You can use the 5.0 wiring harness but you also need a 5.8 PCM for a non computer controlled transmission.
In Ford land the term AOD is not a generic reference to an automatic with overdrive it's an actual transmission so you have to be careful with it, this series of trucks could have also had one of 2 computer controlled 4sp trannys too which were the 4R70w and E4OD, or a C6 3sp, or a manual. Expect to have to change the driveshaft if you use the C6 too.
Old Jan 10, 2016 | 07:06 PM
blageurt's Avatar
blageurt
Another Good Point....
Old Jan 10, 2016 | 08:14 PM
fordman75's Avatar
fordman75
The 4R70W wasn't around in 90 was it? I thought that came in later models.
Old Jan 10, 2016 | 08:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first 4R70W was in the 1993 Mark VIII. It didn't get into the trucks until a bit later.
Old Jan 11, 2016 | 08:32 AM
chaindrive75
Thanks for all the input! Gonna go ahead with it as I've already got the Bronco(for $100). One more question, can I go with the carb on the 351 if I need to have a cat converter on the van?
Old Jan 11, 2016 | 10:39 AM
jbwheels's Avatar
jbwheels
...One more question, can I go with the carb on the 351 if I need to have a cat converter on the van?
That depends.
Yes, you can run a carb on an engine with a catalytic converter. If the crabs tuned right, it won't hurt the cat.
But, if your local/state emissions laws allow you to put replace EFI with carb, then you probably don't need the cat, either.
Old Jan 21, 2016 | 04:54 AM
chaindrive75
Colorado's front range requires the cat and probably the EFI.
MUSKRATT2
23
Aug 15, 2011 09:01 AM
torquemeister
Engine Swaps
Nov 8, 2008 10:12 AM
bgblktruk
1978 - 1996 Big Bronco
Nov 16, 2005 08:55 AM
78bigbronco
Sep 12, 2003 02:28 PM
Crazed
Apr 20, 2003 02:47 AM
