351 in a bronco
Old Mar 26, 2003 | 08:34 PM
Crazed's Avatar
Crazed
351 in a bronco
If i switch from a <a href="http://www.motorhaven.com/">302 </a>to a 351 in an 89 bronco, do I need the wiring harness? I found an 89 351 bronco in a wrecking yard, can I just use the computer and my wiring? What else do i need to know?
Old Mar 26, 2003 | 08:39 PM
Crazed's Avatar
Crazed
351 in a bronco
I also found a 95 <a href="http://www.motorhaven.com/">351w </a>with 40K and no computer for $1100 is this good? I would probably end up with troubles putting this one in?
Old Mar 26, 2003 | 09:39 PM
gamehunter's Avatar
gamehunter
351 in a bronco
That is a very good deal for a 95 with only 40k. You CAN use the same wiring harness and even the same computer if you like. However, performance will be a little better with the 351 computer from what I hear. You should have very little compatibility issues also.
Old Apr 1, 2003 | 05:50 PM
rprice's Avatar
rprice
351 in a bronco
Crazed,
I recently swapped out a 302 for a 351W stroker in a 93 F-150 with an AOD. The 95 351W engine you described is a good deal-plus this year 351W has the factory roller cam. The Y-pipe (exhaust) will need to be replaced since the 351W is slightly higher and wider than the 302. Also, try to get the AC/PS and Air Pump/Alternator brackets that go with the 351W - I know the AC/PS bracket is different between the 302 and 351W. As Gamehunter said, the wiring harnesses and computers should work OK.
BUT - The most important thing for your swap is to use the correct flexplate between the engine and transmission. DO NOT use the flexplate that comes with the 351W-it will most likely be for a C6/E4OD transmission and this will not mate properly with the AOD. You need Ford P/N EOAZ-6375-A. Go to this web site - http://www.bulkpart.com/FLYford.html. They have this flexplate for about $23 or you can buy it from your local Ford dealer for about $95.
Don't waste time trying to find this flexplate in a wrecking yard - Ford only put the AOD behind the 351W from the factory for a very short time in the early 80's. I would be sure and change the transmission fluid and filter in your AOD and be aware that the added torque of the 351W will probably shorten its life.
Ron
Old Apr 20, 2003 | 02:21 AM
Speck615's Avatar
Speck615
Question 351 in a bronco
I know this has nothing to do with the original question, but was just wondering if the AOD trans will fit in my 1980 Bronco. I currently have a 351M, Motorcraft 2150 2 BRL, C6 transmission and a NP208 transfer? How much modifacation will i have to do to crossmembers and drivetrain? I would really like to switch the Mod motor to a Windser, but i think that might be more work that can afford at this point.
No Email Addresses In Posts![/b])]Please email me if you have any suggestions
Old Apr 20, 2003 | 02:47 AM
Crazed's Avatar
Crazed
351 in a bronco
Your engine has a different bolt pattern on the bellhousing so it wont bolt up.
bronco89z
Apr 3, 2009 01:57 PM
tonfro
1978 - 1996 Big Bronco
19
Mar 21, 2008 03:07 AM
Chuky66
Dec 12, 2004 10:48 PM
89Bronco_EddieBauer
Feb 18, 2004 08:59 PM
Broncoguy89
Feb 6, 2004 11:02 AM
