I Was Wrong - VIN Decoding
After many months of ownership I was working on getting the horn operational. In removing the horn for repair, curiosity got the best of me and I started sanding down the frame to find the VIN.
Now the prior owner thought it was a 46, it is registered as a 46, so heck it's a 46. Not so fast.
To my surprise the VIN read, *799T-1660994*
Guess I got me a 1947 tonner!
Now I have to change my user name, rats.
Craig
Still learning a lot about this old truck. I got my information from the below data. But, it looks like the year are the first 3 digits? 799 prefix seems to be a 47.
Tech Tip - Ford V-8 Serial Numbers
FRAME AND ENGINE SERIAL NUMBERS
There is usually no engine number stamped in the block, but the transmission bell housing was factory stamped with a number which, when the car was assembled, becomes the vehicle serial number.
The frame numbers which match the engine (transmission) number is usually stamped in three places on the top surface of the left-hand frame rail (front, center and rear). The only number which can be seen with the body mounted is the front number. The prefix was usually omitted from the center and rear frame numbers.
For Ford cars, the frame numbers started in 1932 with *18-1* (* being a star) and ran consecutive until the end of production in February, 1942. Mercury production began in 1938 with '39 models at *99A-1* and continued sequentially to the end of production in 1942.
Post war production began in 1945 ('46 models) continuing the Mercury sequence (*99A-etc-.*) for both Fords and Mercurys. This is due to the fact that the same 100hp 239 cubic inch engine was used in Fords and in Mercurys. The sequence continued to the end of production in 1948, the only changes being in the 1947 prefix (799A) and in the 1948 prefix (899A).
The year end cut off numbers are only approximate as some assembly plants could have engines left over from the previous model year that would be assembled into cars for the next model year. The reverse situation could also occur.
This information was compiled from various sources and we wish to thank the Ford archives as well as each of the V-8 times advisors for their assistance. The data is as accurate as we have available at this time. If time proves that some of the information is incorrect or omitted, we apologize. If you are aware of new or conflicting facts, please email us.
APPROXIMATE YEAR END SERIAL NUMBERS BY YEAR
FORD, 221 CID V-8
....................................START......... ......................................FINISH
............1932................18-1................................................. ....18-203,126
............1933................18-203,127..........................................1 8-457,477
............1934................18-457,478..........................................1 8-1,234,356
............1935................18-1,234,357.......................................18-2,207,110
............1936................18-2,207,111.......................................18-3,331,856
............1937................18-3,331,857.......................................18-4,186,447
............1938................18-4,186,448.......................................18-4,661,000
............1939................18-4,661,001.......................................18-5,210,700
............1940................18-5,210,701.......................................18-5,896,294
............1941................18-5,896,295.......................................18-6,769,035
............1942................18-6,769,036.......................................18-6,925,898
MERCURY & FORD
239 CID V-8
............1939................99A-1................................................. 99A-101700
............1940................99A-101701.......................................99A-257100
............1941................99A-257101.......................................99A-446700
............1942................99A-446701.......................................99A-539426
WWII PRODUCTION
............1946................99A-650280.......................................99A-1412707
............1947................99A-1412708...................................799A-2002282
............1948................799A-2002283.................................899A-2374315
NOTE: It has come to our attention that there may have been serial numbers beginning with 699 for 1946 vehicles, instead of 99 as listed above.
ALSO, For 1942-1947 Pickups, a letter after the first numbers indicate the size truck: C = 1/2 ton, Y = 1 ton, T = 1 1/2 ton
60 HP PRODUCTION
1937 started with 54-6602
1938 started with 54-358,335
1939 continued from 1938 to 54-506,500
1940 54-506,500 to the end.
There are other number sequences for 4 CYL 32-34, 4 CYL 41-42, 6 CYL 41-48. Some early 1933 model V-8'S used a "40" prefix.
Contributed by Dan Krehbiel, CA
Measured between the hubs, rough number is around 136ish. Frame is double channel part of the way back.
Still learning, a lot here so bear with me.
Also, none of the tonners had duel wheels. It looks like your truck has a nice rust free frame!
So what is a 1.5 or 2 ton called?
