HELP: Steering wheel removal.
Old Jan 9, 2016 | 01:05 PM
Django.Amadeus's Avatar
Django.Amadeus
Trying to pull my steering wheel so I can replace the turn signal switch on my 1977 f250.
I took off the horn cap.
I removed the center nut.
I attached the wheel puller (NAPA) with 2 bolts.
I turned/cranked down on the center bolt on the puller but nothing wants to come off...
What am I doing wrong?
Old Jan 9, 2016 | 01:10 PM
HIO Silver's Avatar
HIO Silver
Sometimes they're just stuck.
Spray some penetrant into the splines and install the puller. Make sure the side bolts are even and then slowly turn the center bolt to apply the pulling force.
If it doesn't release, using both hands squarely slap the steering wheel towards you. Wearing a face shield might be a good idea depending on how hard you slap it.
Old Jan 9, 2016 | 01:25 PM
gatorfor88's Avatar
gatorfor88
You might also try putting some pressure on it with the puller and hit the bolt that is in the center that actually pulls the wheel. Dont beat the snot out of it,just give it a good hit with a hammer.
Old Jan 9, 2016 | 03:35 PM
GM4WALLS's Avatar
GM4WALLS
I have had great success in junk yards just backing the nut out to the end of the threads, grabbing both sides of the wheel and pulling hard as the wife taps the nut gently with a ratchet.
Old Jan 9, 2016 | 05:59 PM
PA74F250's Avatar
PA74F250
I've never used a puller yet on any of these trucks. I always back the nut off till its flush the smack ot with a hammer while pulling up on the wheel. You don't have to hit hard just hit it square.
Old Jan 9, 2016 | 07:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Lube the splines, install the puller, tighten down and tap a bit, it should pop right off.
Old Jan 9, 2016 | 08:10 PM
Pickupmanx2's Avatar
Pickupmanx2
I have had to give a nice sharp RAP on the end of the puller once or twice before,,, once you have puller tight, just a nice solid tap, worked every time for me!
Old Jan 9, 2016 | 08:14 PM
mountain dewd's Avatar
mountain dewd
Never needed a puller. A little pressure on the wheel toward you and a good smack with a BRASS hammer does the trick with zero deformation.
Old Jan 10, 2016 | 08:16 AM
Django.Amadeus
Thank you for all of the good advice.
Donnalee
Jun 22, 2016 09:34 PM
Witty73
Apr 16, 2010 06:27 AM
63' f100
Sep 13, 2009 02:26 PM
rnelson664
13
Mar 24, 2007 02:59 PM
bci101tractors
Aug 15, 2006 09:18 PM
