Need information
Old Jan 8, 2016 | 11:31 AM
atomman1's Avatar
atomman1
Need information
I'm looking at a 2013 F150 FX4 Ecoboost to replace my 2005 Nissan Titan. I like to do research before I buy and would like to determine if this truck has the Max Tow Package. Looking at the mirrors, they don't seem to be the "towing mirrors", but just am not sure. I have a pic of the door sticker - is it possible to determine the axle ratio from that? It's at a Dodge dealership and the salesman isn't familiar with Ford's. Any help with this is greatly appreciated.
2013 Ford F150 FX4, $32,000 - Cars.com
Old Jan 8, 2016 | 12:34 PM
Olytlr's Avatar
Olytlr
3.55 Non Limited Slip. I didn't think a max tow package would come on an FX4.
Also, the Tow mirrors weren't standard on the Max Tow package on Canadian trucks. It was an option. If you are interested in this truck go over it with a fine tooth comb. Get underneath and inspect the frame for rust. It does look clean. There is probably a decent amount of room to negotiate since it is a Canadian truck and was probably a pretty cheap auction buy.
Old Jan 8, 2016 | 01:59 PM
atomman1's Avatar
atomman1
Excellent; thank you! I will do that if I get serious about it. How could you tell that from the door sticker?
Old Jan 8, 2016 | 03:27 PM
Olytlr's Avatar
Olytlr
Your axle code is 19 which when I googled it I came up with the 3.55 non limited slip.
The Maple leaf signifies it is a Canadian truck.
Old Jan 8, 2016 | 06:00 PM
atomman1's Avatar
atomman1
Well that makes sense... Thank you.
Old Jan 9, 2016 | 07:20 AM
NASSTY's Avatar
NASSTY
I'm not sure if it's different in Canada but in the US a Max Tow FX4 would have 3.73 gears.
Old Jan 9, 2016 | 04:42 PM
Olytlr's Avatar
Olytlr
I think it's the same on Canadian Trucks as well. I think the only difference is the tow mirrors are optional.
Old Jan 10, 2016 | 12:17 AM
brokenleg's Avatar
brokenleg
Max tow has a 7700 GVWR too
Old Jan 10, 2016 | 01:23 AM
QwkTrip's Avatar
QwkTrip
I don't know if this is any use to you, but you can get the 2013 product brochure and towing guide from the Ford website.
http://www.ford.com/services/assets/...stalCode=92618
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
Old Jan 10, 2016 | 07:57 AM
mueckster's Avatar
mueckster
Axle code is "L9", meaning it has the 3.55 e-locker. Same as mine. The switch for it is part of the ESOF ****.
Old Jan 10, 2016 | 08:16 AM
mueckster's Avatar
mueckster
Max tow option with a SCrew 4x4, with 3.73 is 11,200# and a GCVWR of 17,100# for the 3.5 Ecoboost. 9,600# with the 3.55 (L9) axle; according to the 2013 F150 towing capacity chart.
File Type: pdf
Old Jan 10, 2016 | 12:40 PM
QwkTrip's Avatar
QwkTrip
FYI - the towing guides for each year are here,
RV & Trailer Towing Guides | fleet.ford.com
Old Jan 10, 2016 | 10:19 PM
Izzy351's Avatar
Izzy351
Do you specifically NEED the Max Tow package? Or is 9600 lbs enough? Just curious...
Old Jan 11, 2016 | 10:35 AM
atomman1's Avatar
atomman1
No, I don't have to have it. I prefer the 3.55 gears, but wanted the larger mirrors and tranny cooler. From researching on here, it sounds like it'll do well even without the Max Tow Package. Thank you!
Old Jan 11, 2016 | 11:22 AM
Izzy351's Avatar
Izzy351
From everything I've read, the trans cooler is the same between tow package & max tow. I have the cooler, brake controller, and 3.55 EL Diff. I too like the larger mirrors because I'm used to my old F250 tow mirrors. You can add them yourself though -- they can be found online and installed pretty easily. The Max tow adds 3.73 gears and bigger mirrors.
Richwon4
Apr 5, 2017 06:01 PM
the_auto_tech
2009 - 2014 F150
16
Feb 27, 2015 08:08 PM
f150crewcab
May 16, 2012 08:30 AM
freeonboard
2009 - 2014 F150
Apr 14, 2011 08:11 PM
Country Traveler
Jan 12, 2011 01:53 PM
