Gauge Lights Dim, Will this work?
Old Jan 8, 2016 | 07:59 AM
MKLC's Avatar
MKLC
The green lights on my instrument cluster are rather dim. I found something on ebay. Will this work and fit in my 1994 F150 5.0
10x Ice Blue T10 Wedge Gauge Cluster Instrumental Panel Speedometer LED Light | eBay
Old Jan 8, 2016 | 09:23 AM
Fastback460's Avatar
Fastback460
It should help, but you would need a 194 bulb for behind the cluster.
And in case you don't already know, turning the headlight **** will adjust the brightness.
Old Jan 8, 2016 | 03:01 PM
Bird-Dog 250's Avatar
Bird-Dog 250
Led bulbs, and I don't know for sure in all cases, but LED bulbs hooked up to a dash light dimmer switch will make them flicker. You're sure the **** is turned up all the way to bright?
Old Jan 8, 2016 | 04:21 PM
madpogue's Avatar
madpogue
^^^^^ That depends on the bulb. Some LEDs are dimmable, some are not. I have LEDs in my '85 IDI, and I've tried them in one of our '95s, and they dim just fine without flicker. You just have to carefully read the item listing, whether it's eBay, Amazon, SuperBrightLEDs, wherever, to see if they're listed as dimmable.
Old Jan 8, 2016 | 06:05 PM
MKLC's Avatar
MKLC
I did not know about turning the ****. Problem solved thanks
Old Jan 8, 2016 | 07:07 PM
jtorsey91's Avatar
jtorsey91
In case you didn't know as well turn all the way counterclockwise until it clicks and that turns the work light on and lights up the bed.
Old Jan 8, 2016 | 07:34 PM
Bird-Dog 250
It might be a good idea to push, pull and turn all the ***** and switches at this point
Old Jan 8, 2016 | 07:44 PM
madpogue's Avatar
madpogue
^^^^ Or maybe READ the OWNER'S manual....
Old Jan 8, 2016 | 08:56 PM
Fastback460
I found that out the hard way, and drained my battery dead one day
Bossdrum
Sep 11, 2012 09:52 PM
bbri4570
Feb 2, 2008 06:40 PM
mbrownone
Electrical Systems/Wiring
Jan 13, 2007 11:52 PM
JoeBlow
Sep 27, 2004 02:51 PM
JEDWIN
Feb 10, 2004 07:21 PM
