LMC cup holder
Old Jan 7, 2016 | 09:36 AM
F-250 restorer's Avatar
F-250 restorer
LMC cup holder
I ordered the lmc cup holder that inserts where the ashtray goes. The ashtray is removed and the holder inserted. I was surprised to find that the part which inserts right into the ashtray slides, is like 10" long! It also need about 60-70 lbs of pressure to shove the ... thing in there.
The description says nothing about cutting the insert, but surely that would have to be done to keep the insert from interfering with wiring. It would also need some sanding on the insert to make it slide in a bit easier.
Old Jan 7, 2016 | 03:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Nice to know, how about a touch of grease on the ash tray track to help with the install?
Old Jan 7, 2016 | 04:07 PM
F-250 restorer
Of course, but by doing so am I voiding the possibility of a return?
Old Jan 7, 2016 | 08:29 PM
77&79F250's Avatar
77&79F250
Sanding marks will show, grease will clean off....60-70 lbs of pressure to shove the thing in there will show also?
Cut it shorter, grease it up or sand it down and just and own it.
Old Jan 7, 2016 | 08:51 PM
tbear853's Avatar
tbear853
If it's where you want .... and ashtray openings don't move ..... fix it and use it.
Old Jan 9, 2016 | 06:21 AM
four-sixty-power's Avatar
four-sixty-power
we tend to "make do" with what we have on these forums
Old Jan 9, 2016 | 12:28 PM
Djstright's Avatar
Djstright
No a little lube shouldn't hurt anything. You could always clean it off real good in the even of a return. I was going to order one of these for my truck but it says it only works with column shift trucks. Would you happen to know anybody with a floor shift truck that you could try it in? I'm curious about how bad it interferes with the shifter.
Old Jan 9, 2016 | 06:07 PM
410 Highboy's Avatar
410 Highboy
Mine I fits okay . Somewhat hard to insert . It is thought out . Leaves room to use radio and cigarette lighter ( mine has been changed over to an outlet ).I might put a strut behind the dash for my own satisfaction .
Old Jan 9, 2016 | 07:52 PM
F-250 restorer
If it interferes with the shifter of the ZF I'm putting in, I'll send the shifter out and have it made into the 'short shift' system I see offered for $200.
Old Jan 10, 2016 | 09:47 AM
Blue and White's Avatar
Blue and White
I used one of those for a while. It was kinda handy. Mine was vinyl covered particle board. When it broke, it took a while to find where I saved the ash tray.
Moral to the story, remember where you stash the ash tray!
D8chumley
2009 - 2014 F150
15
May 8, 2011 08:53 PM
___
Aerostar
Aug 24, 2007 11:13 AM
87carbed
Garage & Workshop
24
Jun 22, 2005 03:42 AM
bigdaddyII
Garage & Workshop
May 8, 2005 12:17 PM
Ken2600
Garage & Workshop
Jul 9, 2003 08:33 PM
