turbo lag???
Old Jan 6, 2016 | 01:18 PM
Mikenski's Avatar
Mikenski
turbo lag???
When I cruise along at 45mph, and the tach is around 1100 rpm and not running hard, no boost it seams like Im in a dead spot in the turbo does this sound right? I've owned the truck since 45k miles, and has always done it, its a 07 f250
Old Jan 6, 2016 | 01:37 PM
WatsonR's Avatar
WatsonR
Yep.... step down a little harder and bam, we're gone!
Old Jan 6, 2016 | 01:47 PM
Mikenski's Avatar
Mikenski
Ok thanks just making sure nothing wrong that it's normal, and thats what I do to get out of it
Old Jan 6, 2016 | 02:52 PM
Euroman's Avatar
Euroman
All these big diesels have loads of lag - watch the boost gradually rise when you step on it.
Mind you, all turbos have some lag...
Old Jan 6, 2016 | 03:02 PM
WatsonR's Avatar
WatsonR
Much less pronounced at higher RPM
Old Jan 6, 2016 | 03:33 PM
Euroman's Avatar
Euroman
That's right, the turbo (centrifugal compressor) has a non-linear characteristic and at higher rpm you're already shifting more air and spinning it faster
Old Jan 6, 2016 | 04:31 PM
DSMMH's Avatar
DSMMH
With the key and engine off, depress and release the gas pedal about 30 to 50 times. I have found that over time the throttle quadrants will get dirty and get a sort of dead spot in them. By doing this, it has a tendency to clean them. Kinda works like a CD player cleaner without the brush. You should see a difference in throttle response. I do it monthly on my X, ZR1 and Super Bee.
FWIW - Back in 2006 I installed a honeycomb device called a TAG (Turbo Air Guide) at the compressor inlet. This directs the inlet air to the center of the compressor wheel vice the air hitting all over the compressor wheel. It makes the compressor more efficient, reducing lag.
Ed
Old Jan 6, 2016 | 05:10 PM
WatsonR's Avatar
WatsonR
Did you mean key on, engine off?
Thanks Ed!
Nail it 5 times a day do the same thing?
Old Jan 6, 2016 | 07:48 PM
DSMMH's Avatar
DSMMH
Thanks Ed!
No, just work the pedal with everything off. I would just hit it about 50 times in a row like you are nailing it and see what happens.
Ed
mikec91
Feb 4, 2013 08:26 PM
go6.0go
Feb 2, 2009 09:47 AM
Malikenya
Jan 13, 2007 12:08 PM
Ben Alston
Oct 12, 2004 07:04 AM
