No power, dies once up to temp but restarts fine
hey guys so I have an 07 6.0 diesel and I'm having trouble once it gets hot. It begins to lose throttle response and shakes while cruising and also has a rough idle. sometimes it dies while idling but after cooling off for a few minutes starts back up and runs fine. I've checked the high pressure oil and the ficm and both of those are fine. I've done an EGR delete so it has nothing to do with that either. My MPG also goes way down when this happens. any suggestions as to what might be the problem?
You'd be amazed at how bad one bad injector will make it run. You need to get your fuel pressure tested and make sure it is greater than 45 PSI at wide open throttle so you don't lose anymore injectors.
jdneal88
16
01-02-2017 12:35 AM
