390 ticking
Old Jan 5, 2016 | 04:45 PM
Paddrick Smith's Avatar
Paddrick Smith
390 ticking
My 390 is ticking and not staying started.I pulled the valve covers and found carbon build up one cylinder per side i.e. driver passenger. any connection ?
Old Jan 6, 2016 | 01:52 PM
mark a.'s Avatar
mark a.
"carbon build up" would be in the combustion chambers or in the exhaust ports. Sometimes if the intake valve is leaking it can back up into the intake ports but by just removing a valve cover you can't see any of that, so I don't get your question ?
Old Jan 6, 2016 | 02:53 PM
Truck Noob's Avatar
Truck Noob
could it be a leaky valve cover gasket leaking oil into the spark plug recess causing a short? when a plug is shorting like that it sounds like a ticking and with the loss of that plug (or more) it would cause issues.
Old Jan 12, 2016 | 04:50 PM
notmyrealname's Avatar
notmyrealname
Your ticking is more than likely an exhaust leak where the manifold meets the head.
Marauder2004
33
Sep 10, 2014 09:41 AM
otpracer100
Mar 4, 2007 03:35 PM
Diggerz_44
Aerostar
May 16, 2006 01:56 PM
grw289
Jul 16, 2004 08:07 AM
gtex
Mar 16, 2003 10:36 AM
