removing valve cover
Old Mar 15, 2003 | 05:00 PM
gtex's Avatar
gtex
Now, I'm almost sure my 352 has never been rebuilt.
Any susggestions for getting the valve cover off. It is being pretty stubborn! I've whacked it with a rubber mallet, wedged a screw driver between it and the head and it's not moving.
I've got what I thought was an exhaust leak, but sounds like it's in the valve cover or head. Am I looking at a bad valve, pushrod or spring?
Old Mar 15, 2003 | 06:05 PM
gtex's Avatar
gtex
It came off after another beer...I mean. after a little more force in the use of the rubber mallet.
Still can't tell what the noise is, it's internal but sounds like an exhaust leak. The truck runs pretty good.
Any ideas appreciated!
Old Mar 15, 2003 | 07:33 PM
Mike W's Avatar
Mike W
Make a close check of the exhaust manifold and gasket.
Old Mar 15, 2003 | 07:50 PM
gtex's Avatar
gtex
I here ya, but I didn't feel anything around the head gasket or header gaskets.
I went underneath and so did my friend, we both think it's internal. Nothing obvious after the valve cover was off.
It may be a bad lifter , but the sound is much "SOFTER" than I am use to.
Old Mar 16, 2003 | 06:55 AM
jowilker's Avatar
jowilker
g, After following your posts for several months, you are gonna replace it with a kick butt motor anyway, so why worry?
Old Mar 16, 2003 | 08:18 AM
gtex's Avatar
gtex
It runs pretty good, I'd like for the second truck to be a runner if not pretty. I was surprisd how good this 352 runs.
The noise is pretty loud and annoying. A real jalope mating call :-)
Old Mar 16, 2003 | 10:36 AM
Mike W's Avatar
Mike W
How about doing a compression check? That should tell you what kind of shape the engine is in. I had a friend with a 351w that had a 3/8 wide hunk of exhaust valve missing. He drove it like that for 6 months before replacing the engine.
hillbillyk
Dec 26, 2018 07:53 PM
TSTITT
13
Oct 3, 2016 06:44 PM
FREDDAY
May 20, 2016 05:15 PM
breezesboy
Oct 30, 2014 05:33 PM
DutchmanAZ
18
Sep 19, 2014 01:32 PM
