Finally ordered my tuner!
Old Jan 4, 2016 | 08:08 PM
Budlight592's Avatar
Budlight592
Waiting on the X4 to come in and the delete pipe and started thinking what am I going to put in the empty temp. spots on the EDGE CTS monitor. How is everyone reading EGT's. Would like to do the egr delete but worried about breaking the dreaded bolt off. Anyone have any advice or input on this would be great. Hope everyone had a great Christmas and New Year.
Old Jan 5, 2016 | 05:06 AM
rodfarva's Avatar
rodfarva
I just deleted my mid-late model year 2011 with 68k miles as the 5yr warranty has ended and my DPF heater was bad. Plus I'm tired of EGT sensors failing and rendering the truck useless. I did have trouble with one of the bolts on the longer EGR pipe where it attached to the passenger side exhaust manifold. Fortunately, I was able to get one of the bolts loose (I had previously soaked in penetrating oil for over 24 hours) and was able to pivot the entire pipe back and forth enough several times to enable the other bolt to loosen up. I hope this helps!
Old Jan 5, 2016 | 08:34 PM
EO2SeaBee's Avatar
EO2SeaBee
That's awesome! Who did you end up using?
Old Jan 5, 2016 | 10:36 PM
Budlight592
Rudys Diesel. Should be here Thursday evening.
Old Jan 5, 2016 | 10:49 PM
EO2SeaBee's Avatar
EO2SeaBee
Good deal. They took care of me pretty well. If you need customer service, I think you will be satisfied. If you don't need CS, you will still like the tunes.
Old Jan 5, 2016 | 11:13 PM
Budlight592
Yep sure hope the custom files are good. You still running with the EGR unplugged? I forgot your on nights, wish I could sleep I came off this morning so not having much luck going back to sleep.
Old Jan 6, 2016 | 01:40 AM
EO2SeaBee's Avatar
EO2SeaBee
Yes to both. I am on nights, and I'm still running unplugged. Switching from nights back to days SUCKS!!
Old Jan 7, 2016 | 09:08 PM
EO2SeaBee's Avatar
EO2SeaBee
Any updates? Pics? Impressions?
Old Jan 8, 2016 | 09:14 AM
2011F-250KR's Avatar
2011F-250KR
I had/have the same situation and I am also thinking about delete.
Old Jan 11, 2016 | 08:54 AM
Budlight592
Well so far its only been a week and I am glad I did the delete. Went from 13.8 to right at 16 mpg according to the dummy gauge. No drone in the cab at any speed, sounds great at idle. Would like to figure out how to monitor some EGT with the EDGE insight but haven't been able to figure that one out yet. EGR is disable but not unplugged, according to Rudy's just leave it plugged in, it already disabled.
HAMMERDOWN103
6.4L Power Stroke Diesel
Jan 29, 2022 04:27 AM
StanleyZ
6.7L Power Stroke Diesel
33
Nov 5, 2019 06:37 PM
Thelenny999
Nov 15, 2017 10:04 AM
DeeDubz
Nov 20, 2016 03:59 PM
ngng
19
Jul 8, 2014 08:56 PM
