Torque pro help
Old 01-05-2016, 02:05 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
Originally Posted by dustinsheeler717
Is there anyone at all using the mini vgate Bluetooth adapter?
I don't know what mine was called, or if it even had a name, but it is one of the blue translucent mini-ELM 327 units and works fine (for years now), however the first one was flaky I got from the seller. And it is one of the cheap-o units...
2 things I'd try: 1st get a hold of your eBay seller -- mine was a US seller and immediately shipped me another, no return required: seller was TomTop or something like that but there are a lot of different eBay IDs that go back to the same actual dealer. Get another one on the way to you...
2nd: is I'd start playing with the adapter comm settings from the torque side: turn Off Faster Comms if it is On and Turn On Disable Auto Timing. Since you are getting some PIDs it could be how fast it can interrogate the CAN Bus and get back data correctly.
Good luck!
Old 01-05-2016, 04:48 PM
dustinsheeler717's Avatar
dustinsheeler717
dustinsheeler717 is offline
Thanks dan. I will try that and if no luck will get a hold of eBay seller for a new one.
Old 01-05-2016, 05:35 PM
diesel_dan's Avatar
diesel_dan
I'd probably try and get a replacement coming in any case. My El Cheap-o can even handle enabling faster comms -- usually that is turned off when you first load Torque. The first one I got would drop the connection to the PCM pretty often -- I've read that can be a problem when trying to go faster on the communication, but I hadn't even tried doing that with my 1st unit...
I'm sure you'll get it figured out
Old 01-06-2016, 11:31 PM
dustinsheeler717
Yeah I have the same one you have. It's just there's no oil temp reading. It's there just doesn't have a reading. I messaged ebay seller.
Old 01-07-2016, 05:17 PM
2wdDezlX's Avatar
2wdDezlX
2wdDezlX is offline
Could it be the temp sensor or wiring to it?
Old 01-07-2016, 08:11 PM
diesel_dan's Avatar
diesel_dan
Good point, but he was initially saying the FICM readings were low as well. The temps you could swap and see if the problem follows. Since he's just getting started there could be other readings not quite "right", so we'll need to see what else is looking weird in the real time gauges...
OP: Pull up Vref as one of your real time gauges too and see if it is reading 5 volts...
Old 01-08-2016, 03:02 PM
HP junkie's Avatar
HP junkie
HP junkie is offline
There are different versions of the ELM327. I found out the hard way. You need to make sure you get the right protocol for your truck. I ordered v1.5 and v2.0 first one reads up to 07' and the second 08' and up.
Do some research and make sure it has the Ford protocol for your truck.
FrankNBeans
01-25-2017 02:56 PM
mcompton1973
01-01-2016 01:18 PM
bansheemike
06-01-2013 04:48 PM
egregg57
01-16-2013 12:25 PM
bond10
12-29-2005 05:56 PM
Quick Reply: Torque pro help
