Right side passenger window...
Old Aug 8, 2003 | 07:56 AM
97expy5_4's Avatar
97expy5_4
I'm unable to roll down the right side passenger window. I've checked all the fuses and even checked for voltage at the window controls, all seems well. All the other windows work fine. Any thoughts?
Thanks
Big Mick
Old Aug 8, 2003 | 09:18 AM
jdadamsjr's Avatar
jdadamsjr
if voltage sycles when you hit the botton, then I would suspect your window motor...
Old Jun 8, 2009 | 08:31 PM
ctlyste's Avatar
ctlyste
I'm having the same problem, where would i look for the fuses?
Old Jun 8, 2009 | 09:58 PM
Monsta's Avatar
Monsta
Sit. Stay.
Um... in the fuse box? It's under the dash. Access via the knee bolster plate below the steering wheel.
Do you have an owner's manual? Some folks who buy pre-owned have had it missing.
Old Jun 8, 2009 | 11:38 PM
wallz's Avatar
wallz
First, welcome to FTE.
If you need a manual you can download one from this link:
https://www.fleet.ford.com/maintenan...ls/default.asp
If all the fuses are good, then I would pop the door panel and check all the connections. Here is a link for the panel removal. Same as the the superduty.
Door panel removal
Old Jun 9, 2009 | 06:36 AM
SFeintuch's Avatar
SFeintuch
If only one door is out it is not a fuse or relay. here is a quick way to check with car off just turn key to on position. Then turn on your interior lights by opening a door. Try the window that does not work,If the interior lights dim it means your motor is jammed or bad. If the light does not dim you have a bad switch or broken wire. If it does dim go to the door that isn't working and with key on and switch pushed to open position slam the door hard a few times or just bang on the interior panel. If it is jammed 90% of the time the window will start working again. Plenty of motors have been changed for just being jammed.
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
fosterslager
Jan 8, 2012 12:49 PM
windstarharv
Oct 6, 2007 10:45 AM
crashed13
Mar 4, 2006 12:28 AM
WXboy
1983 - 2012 Ranger & B-Series
May 1, 2003 08:23 PM
