inertia fuel pump cutoff switch missing - need to replace?
Old Jan 3, 2016 | 12:51 PM
dbrydon's Avatar
dbrydon
In my 01 Excursion:
Strangely, where the inertia fuel pump cutoff switch should be, there is a broken plastic mount on its screw that used to hold it to the car body. The switch is nowhere in sight. The Chilton's manual shows a wire going to it from one of the wire plugs there, but I don't see any cut or broken wires.
Is that OK or should I work to find it or replace it if it really is missing?
Old Jan 4, 2016 | 01:01 AM
Apocalypse's Avatar
Apocalypse
Does the truck run fine? Then forget about it
Old Jan 4, 2016 | 06:31 PM
holeshotwalt's Avatar
holeshotwalt
I believe the purpose of that switch is to shut off the fuel pump if the vehicle is hit really hard or gets upside down.
Now, call me over-protective, but I would like to NOT have fuel pouring out of the vehicle onto me if the truck was on it's lid.
I'd replace the relay.
Old Jan 4, 2016 | 07:36 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'd be interested to know why someone would take it out. I am with Walt. That is a necessary safety feature. You never know what the future holds...
I have worked DOZENS of crashes over the years where those fuel cutoff switches did their jobs. I would want to keep mine.
Old Jan 4, 2016 | 10:43 PM
Apocalypse's Avatar
Apocalypse
Keep mine, yes. Go to Ford and buy a replacement, no. Yes they stop the fuel pump from running when they are tripped but I have also removed one myself. I took mine out of my 01 Focus because I would Rally it off road and the bumps would trigger it and kill the car. If I had unlimited money I would have everything 100% OEM on my truck and nothing missing but I don't so if I found something missing I would make due.
Old Jan 4, 2016 | 11:35 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
I have to disagree this time Jon. If it's a safety feature that can mean the difference between me, my wife, or most importantly - the kids from further harm... I'll break the bank to take care of it.
Old Jan 4, 2016 | 11:41 PM
Apocalypse's Avatar
Apocalypse
Well with kids riding along that totally changes things. My truck isn't for hauling a family around in, much less a ton of driving. If I was putting hundreds of miles on my rig and had lots of passengers (especially with little feet) I would make sure it was installed and operational.
Old Jan 5, 2016 | 02:37 AM
Bently_Coop's Avatar
Bently_Coop
Why make an exception for this? What about your Wife and Dogs? Are they not the same? I wouldn't limit it to mileage, distance or strength a child has.
It isn't just a feature for you, it is for your passengers and everyone around you should something happen.
tomasz646
Sep 24, 2012 07:26 PM
tomasz646
Mar 8, 2012 07:12 PM
Dutter
1983 - 2012 Ranger & B-Series
31
Sep 27, 2011 10:45 PM
Ranger3L
3.0L V6
May 14, 2004 07:19 PM
