The Coolant Temperature Sender wire color is Red/white stripe. Only one wire. You can see it from sitting under the passenger side looking up between the fenderwell and the exhaust.
Yea my oil one looks like the one in the second pic. I do believe you are correct about it being an idiot light. I will try grounding the temp wire. Sorry, this may be a stupid question, but what exactly do u guys mean by grounding it? I've never had to do this before. Pull the wire off and put it on a bolt that's grounded?
