no temp/ high temp
Old Jul 2, 2015 | 05:46 PM
bcaughhorn's Avatar
bcaughhorn
no temp/ high temp
My temp gauge started jumping around. I put a new sensor in knowing that wasn't the problem...
Is there a common place that the pigtail shorts out?
My dash gauge stays on the C my live wire starts out at -250 then made its way up to 230. I know my motor isn't changing 480 degrees.
Old Jul 2, 2015 | 06:25 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
You won't be able to read accurate coolant temp through a scan tool, since the PCM does not monitor coolant temp. That sender is only there for the gauge on the cluster.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Jul 2, 2015 | 06:30 PM
bcaughhorn's Avatar
bcaughhorn
Yea that's why I was asking if there is a common spot for a short on the pigtail or the wiring for the temp sensor
Old Jul 2, 2015 | 06:34 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Not really. You can get a multi meter on there and check continuity on the wires though, if you feel that is the problem.
I was just simply trying to tell you what you are seeing on the Livewire is normal. You will get a reading, but it will never be accurate, since the PCM isn't receiving any info from that coolant temp sensor. Oil temp is the one you want to watch.
__________________
Justin
www.dp-tuner.com
Old Jul 2, 2015 | 06:35 PM
bcaughhorn's Avatar
bcaughhorn
Ok thanks. I'm gonna have to check it out this weekend
ctruf1504x4
Jul 20, 2019 03:44 PM
Hitagain
Mar 22, 2016 07:19 PM
grec-o-face
18
Feb 15, 2013 01:46 PM
caseydudem
21
Jan 15, 2008 07:14 AM
cajun1965
1997 - 2003 F150
Jun 19, 2007 10:55 PM
