Sponsored by: Real Truck
4x4 Help please!
Old Dec 29, 2015 | 05:09 PM
Shotgun29's Avatar
Shotgun29
4x4 Help please!
2005 F-250 King Ranch Diesel
My truck when I got it the 4x4 wouldn't engage. I replace the front inner seals, and the lock outs. Still wouldn't work. Took the shift motor off and freed it up and it worked fin till today. Changed the shift motor and still nothing. This truck has been nothing but problems since I have had it and now this. I don't have the money to take it to a shop and keep replacing parts hoping to find the fix. If you have any ideas please let me know. Truck is going on the market soon and would sell better if the 4x4 worked.
Thanks guys,
Dave
Old Dec 29, 2015 | 05:16 PM
jetjockey99's Avatar
jetjockey99
Have you tried turning the hubs from auto to locked? That is assuming it still has factory auto hubs. If the hubs are aftermarket, they HAVE to be manually locked to function. The factory auto hubs can be left in the locked position and then just use the **** to turn 4X4 on and off, although the hubs will remain locked.
Old Dec 29, 2015 | 05:26 PM
Shotgun29's Avatar
Shotgun29
Hubs are new and are in Lock. It worked a month ago and didn't work today after 8 inches of snow. Auto has never worked in the truck since I have had it.
Old Dec 29, 2015 | 06:19 PM
redford's Avatar
redford
FTE Leadership Emeritus
How are you determining that your 4 wheel drive is not working?
Old Dec 29, 2015 | 09:57 PM
Shotgun29's Avatar
Shotgun29
It snowed 8 inches yesterday and I got stuck in my driveway going to work this morning. I have no four wheel drive. Front wheels do not drive.
Old Dec 30, 2015 | 05:33 AM
redford's Avatar
redford
Did you get any 4 wheel drive light indicator?
Old Jan 1, 2016 | 01:56 PM
Shotgun29's Avatar
Shotgun29
No indicator light
Old Jan 1, 2016 | 02:03 PM
redford's Avatar
redford
IIRC, the indicator light signal comes from the ESOF shift motor.
Shotgun29's Avatar
Shotgun29
Shift motor is brand new
Old Jan 1, 2016 | 02:05 PM
redford's Avatar
redford
2 possibilities here. Your wiring harness for the shift motor is damaged, or the " new" shift motor is bad.
Old Jan 1, 2016 | 02:08 PM
Shotgun29's Avatar
Shotgun29
I've had problems with the 4x4 since I have bought the truck, works when it wants to. Worked a month ago just fine. Lock outs are new, inner seals are new, shift motor is new, running out of parts to replace. Fuses are all good. Might try a new 4x4 switch and see if it works.
Old Jan 4, 2016 | 04:16 PM
Shotgun29's Avatar
Shotgun29
Replaced a melted relay and the 4x4 now works.
Thanks for all of the input.
Old Jan 4, 2016 | 05:24 PM
Diamnd1's Avatar
Diamnd1
Thanks for the update. Glad you got it fixed and working.
Old Jan 4, 2016 | 05:28 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Seems loke your mad ar spending money on the wrong parts. No point in replacing hubs and seals when you didnt properly check step by step for the problem. And it turned out to be a ten dolllar relay, yes the auto hubs can be a problem but with proper maintenance they work beautifully whenever u need them
Bcd18
Oct 18, 2016 10:56 PM
montauk1
Jul 4, 2016 12:36 PM
Tim Hartman
Feb 4, 2009 10:33 AM
jjohn82
Mar 3, 2005 09:37 PM
Machine
Offroad & 4x4
Aug 19, 2003 02:40 AM
