My 69 f100 pig-pen build
Old 01-30-2016, 03:35 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
For the drip rails, I recommend this... paintable and is UV stable. : 3M Heavy Drip-Chek Sealer 8531
  #92
Old 01-30-2016, 06:33 PM
orich's Avatar
orich
orich is offline
I used some stuff about the same set up time on a day that was about 70 degrees that day and 10 minutes is not enough working time.
As you'll need to smooth out with a wet finder if you have any or it become lumpy as your working around the cab.
It would be okay with two guys working together. One applying it and the other working out and uneven areas.
Orich
  #93
Old 02-01-2016, 01:26 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
I think you're doing a good job! It's coming along very well.
  #94
Old 02-01-2016, 07:05 AM
69pig-penf100's Avatar
69pig-penf100
69pig-penf100 is offline
Hey guy's this weekend was pretty event full took advantage of the amazing weather we got in TX. Used a few new toys we got which I'm sure saved me hrs of work!! Can't beat that. We went ahead and bought a blasting cabinet to hit all the small parts after cleaning and got the sand blaster in. So the sandblaster worked great with one down side of burning through the sand faster than the truck drank up gas. That sand is not cheat either I burned through the 50 lbs in a good 15 or 20 min. That's to say I only hit the front end so I could start prepping it for paint.
HIO thanks again your a life saver I spent a good amount of time looking at all kinds of products but couldn't make a choice.
Orich good looking out I'll make sure it's a duo when I start to apply.
Ranger I'm with you if they don't want someone to use the information they provide they shouldn't really be posting it publicly.
Thanks everyone on the great words of wisdom. Your suggestions, and encouragement go a long way. I certainly practiced for hrs this weekend welding different things trying different angles and scenarios.
And here's the snaps I remembered to take
  #95
Old 02-01-2016, 07:47 AM
orich's Avatar
orich
orich is offline
Back in the early 90's when, I sand blasted the under side of my truck. I did it on a cement drive way, then sweep up the sand poured it through a screen filter and reuse it over many times over.
May be you could have used a tarp to catch it and reuse it.
I wished, I had known about Por-15 back then and would have used that to cover everything that got blasted then it would have still been on to this day.
Orich
  #96
Old 02-01-2016, 12:35 PM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
Where did you get your blast cabinet? I know that we have Northern Tool here in Tx. As to sand, I have seen people try river bed sand vs beach sand, and if screened well, the river bed sand will work. Beach sand is full of salt, and has had the sharp edges rounded off some. In Baja, we go way up a stream bed, and shovel bucket loads through a fine mesh screen. It works just fine..
Texas connects us amigo...
Baja
  #97
Old 02-10-2016, 10:26 AM
69pig-penf100
So someone has been buuuusy for sure! But that didn't keep me from putting in some sweet sweet time with little piggy! Let's see I still haven't finished welding the passenger side floor pan keep having blowing out problems so that one is going to be a little more time consuming. But on the bright side I cut and tacked in the driver side floor pan and that looks like it's going to be easier. I made a little trip out to Texarkana and got me a nice disk brake set up from a 76 f150 going to start to replace all the needed worn out parts then install. I'm still doing a little research on the swap to make sure I dot all my I's and cross my T's. I also picked up a new radiator support with only a little bit of surface rust. Other than that just blasted a few more parts! Here's a few pictures enjoy
  #98
Old 02-10-2016, 10:36 AM
69pig-penf100
Baja
Baja my bad I have been glued to the truck and haven't hopped back on the forum but we got the blast cabinet at Harbor freight it filters and reuses the sand the blaster I got is what used up all the sand but that's a good idea I might have to try a tarp and reuse because it will get pricey on the big items free river and sounds nice too lol
  #99
Old 02-10-2016, 05:02 PM
bajafishnut
Thanks amigo, I will look at HF when I get back to CA, and my Baja runner. I have a small portable blaster, from Granger, but it makes a way big mess. When the gears in my brain mesh, I remember to do the tarp on the ground thing... Otherwise, its a push broom and shop vac. A blast cabinet will save a lot of clean up time...
Baja
  #100
Old 02-10-2016, 05:14 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
I have the same HF blast cabinet , pick up a couple cheap 28 led magnetic lights ($0.99)from HF too , I stick them to the inside roof to light up what i am sand blasting .
you can hook up the shop vac too to suck up the excessive dust .
  #101
Old 02-10-2016, 05:18 PM
bajafishnut
Nice shop tricks '68... I will borrow the ideas, and give you credit...Author, author...light is way important, more so now that I am 70..
Baja
  #102
Old 02-10-2016, 09:14 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is online now
blasting media
For a blast cabinet the longest lasting media I have used is aluminum oxide #36, It can be purchased as a #60 with glass bead mix also. When it impacts it breaks with a sharp edge and has a blast life of 30 compared to sand which is considered to have a life of 1. Garnet media falls somewhere in between but makes a lot of dust and is not expensive. I had a 5'x5' cabinet direct pressure system and dust collector when I had a powder coat shop. Sand of course is still best for non recovery and can be used over a few times.
  #103
Old 02-11-2016, 08:15 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
I have a 48" wide 960 Skat Blast cabinet and vacuum unit made by T.P Tools in Ohio. I also use their Skat Magic blast media (finely crushed automotive glass). It's a little more aggressive than regular glass beads. Early on, my gun tips wouldn't last very long before they would be severely worn away. I sprung the $60.00 for one of their carbide tips and I've been running it for several years now (was worth the money).
....just arrived off the freight truck (Spring 2007).
Pro Shop (34"-92"W) Sandblasting Cabinets for Abrasive Blasting Cabinets - TP Tools & Equipment
Most Popular Abrasives for Abrasive Blasting Cabinets - TP Tools & Equipment
  #104
Old 02-11-2016, 01:39 PM
bajafishnut
Now, that is a serious use cabinet amigo... I love it, but sadly, I do not have the space to store it. I am going to look at one of the table top mount units at HF, to see if it will serve my purpose. I have a big outdoors, but not a big indoors. I made an outdoor work bench, from 2 old 10ga. steel sides, from a dump/flatbed. With some welded angle as legs, makes a perfect "Under the palm tree" shaded outdoor work bench. I envy yous Ultra... it must be nice..
Baja
  #105
Old 02-11-2016, 02:00 PM
ultraranger
Baja
Get as big a bead blast cabinet as both finances and space will allow. The other half of the equation is air supply. The blast cabinet is my most demanding tool. When it's operating, it's just like an open air line draining the air compressor.
I got a big enough air compressor (4 months before I bought the cabinet) that even at 90 PSI (or even greater), I don't have to stop and wait for the compressor to catch back up before I can continue on. --I can blast continuously. However, it should be noted that the higher PSI you run your blaster, the faster your media will wear out and have to be replaced with fresh blast media.
My compressor is a Husky 7.5hp, two-stage, 80 gallon tank, 0-175 PSI output and will maintain 23 SCFM @ 90 PSI.
Quick Reply: My 69 f100 pig-pen build
