390 radiator cap
Old Dec 29, 2015 | 07:51 AM
john jamieson's Avatar
john jamieson
390 radiator cap
I have a '64 F-250 that a PO installed a 390 into. I just had the radiator repaired and need to replace the cap. The parts store sold me an 13lb rated solid top cap.
The old cap is 7lb rated and has the locking top. I believe the engine is from '72-'74. The truck does have a now non-working ac system. What rating should my rad cap be?
Thanks.
john
Old Jan 6, 2016 | 11:51 AM
Freightrain's Avatar
Freightrain
Sounds like the previous owner put a light cap on it so it would not blow out the old radiator. the 13# sounds about right.
The locking tab is just an option. Doesn't need to be there. Just allows you to depressurize without turning the cap. Once you have the cooling system working properly you won't need to worry about removing the cap.
Old Jan 8, 2016 | 04:50 PM
MIKES 68 F100's Avatar
MIKES 68 F100
fyi get a STANT cap not the look alike that Autozone /pepboys sells those aren't worth peeing on
Old Jan 9, 2016 | 03:04 PM
69cj's Avatar
69cj
I purchased a Stant cap with built in thermometer on the top. Kinda neat to see what the rad. temp. is before opening her up.
Old Jan 13, 2016 | 06:29 PM
john jamieson
Thanks for the replies. I may have to look for a Stant cap with the thermometer in it. That would also give a comparison to the temp gauge on the dash.
Old Jan 14, 2016 | 02:52 AM
jowilker's Avatar
jowilker
In the about 50 years that I have had a drivers license, I can't recall ever wanting to jump out pop the hood to see what the temp at my rad cap was.
John
Old Jan 14, 2016 | 07:51 AM
69cj's Avatar
69cj
John
Neither have I but I needed a cap, it was reasonable and a good conversation piece when the hood is open. It also is pretty accurate. I paid 20 bucks for it at Pep Boys.
Old Jan 15, 2016 | 06:04 PM
yetiman38237's Avatar
yetiman38237
John
Only because you didn't have the right kind of cap.........
Old Jan 16, 2016 | 05:00 AM
jowilker's Avatar
jowilker
I'd say it was because I DID have the right kind of cap.
John
john jamieson
Dec 30, 2015 08:28 PM
Vegas123
Aug 27, 2015 07:49 PM
abe
Dec 13, 2014 05:42 PM
Bryanblaylock
Mar 20, 2013 02:38 PM
paulcooper1969
Apr 19, 2007 11:56 AM
