Radiator cap
Old Apr 18, 2007 | 11:17 PM
paulcooper1969's Avatar
paulcooper1969
Radiator cap
I went down to my local parts store to get a new radiator cap today and they gave me a 13 lbs cap does that sound correct?
Its on a 1982 Ford F-250 351W
I was running a 17 lbs cap does it make a difference? Any input would be appreciated.
Thanks
Paul
Old Apr 19, 2007 | 12:23 AM
Franklin2's Avatar
Franklin2
The higher the pressure cap, the hotter the engine can run before it boils over. With no cap at all, it will boil over at approx 212 degrees, depending on your altitude. As you pressurize the system, this number goes up.
I don't know what the spec is on these trucks, but most newer vehicles run at least a 15 lb cap. You can run a lower pressure cap if your radiator is in poor shape. I have had some old cars that I ran 7lb caps in to make the old radiator last a little longer.
Old Apr 19, 2007 | 08:32 AM
Kylet8020's Avatar
Kylet8020
franklin2 is right but your truck might not heat up right/cool right if u run the wrong cap ill try to check the cap psi for ya if i get a chance
Old Apr 19, 2007 | 11:33 AM
paulcooper1969
Ok thanks I would appreciate it
Old Apr 19, 2007 | 11:41 AM
Kylet8020's Avatar
Kylet8020
looked it up for a 82 ford f250 2wd with 351 it says 13psi
Old Apr 19, 2007 | 11:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E5TZ-8100-A .. Radiator Cap~13 lbs Fits most FoMoCo products from 1960 thru 2007.
13 lbs is the correct application.
Jay1
Apr 10, 2013 12:18 PM
hatemakings/n
Oct 17, 2006 12:52 AM
imlowr2
May 4, 2006 09:50 AM
PAUL_2
Jan 8, 2000 10:34 AM
