Is it ok?
Dec 26, 2015 | 01:21 PM
Is it ok?
All diesels have blow by from what I read and there is a million different opinions. How much is normal and what if it is coming out of the dipstick?
Dec 26, 2015 | 01:26 PM
Can you take a quick video?
Dec 26, 2015 | 01:46 PM
Pull the boots off the turbo. Then check it.
What is the complaint, other then blow by?
Whats the impeller look like on the turbo?
Dec 26, 2015 | 01:48 PM
To add if it looks like an old coal train, thats bad.
Dec 26, 2015 | 01:49 PM
https://m.youtube.com/watch?v=AlpoSO1R7FY
Here it is
Dec 26, 2015 | 02:04 PM
Its a bit more then I would like to see. Is it like that when warm?
If it came in to the shop I would toss a gauge on it.
Dec 26, 2015 | 02:11 PM
Quote:
Originally Posted by
cheezit
So I should be concerned? I did the cap test it didn't blow off
Dec 26, 2015 | 02:25 PM
If that the only issue, no not really. If its in conjunction with hard starts, lack of power or runs rough possibly.
Once again does it act the same with the turbo boots removed? This could also be the start of turbo issues.
Dec 26, 2015 | 02:28 PM
I don't have any issues what so ever truck runs great starts in under a second no loss of power
Dec 26, 2015 | 02:31 PM
cheezit
Haven had a chance to do that yet
Dec 26, 2015 | 02:43 PM
And it doesn't burn oil either
Dec 27, 2015 | 04:14 PM
cheezit
So I just remove the boot off the turbo and crank it right? Not trying to sound incompetent or anything. But I'm an I.t.not a mechanic lol
Dec 27, 2015 | 04:40 PM
Is the CCV stock or do you have it re routed? If it is stock make sure the hose is not kinked.
Dec 27, 2015 | 05:39 PM
Yes pull both boots off the turbo.
Muddy 13
Jun 20, 2011 06:29 AM
redfire42
Nov 14, 2008 06:38 PM
Learath
Feb 5, 2007 10:44 PM
twg1966
13
Nov 4, 2005 02:20 PM
ktplotts
May 10, 2005 12:05 PM
