U-Joint Question
Old Dec 26, 2015 | 08:03 AM
BBslider001's Avatar
BBslider001
U-Joint Question
What do you guys think on replacing U-Joints? Mine "seem" ok and don't shimmy or make noise, but is there a certain mileage that I should consider replacing all three? The odd thing is the front one is greasable and the two rears are sealed. I grease the front one every 10k or so. I just don't want any issues on the road home and I have had this truck 3 years. No telling how old they are. Thanks. Talk away.
Old Dec 26, 2015 | 08:09 AM
ReBilld's Avatar
ReBilld
Morning Byron! Look around the rubber boots on the caps and see if there is any orangeish brown dust around them. That would indicate it is dry. If they are all tight, and not dry, they should be fine, but they are one of those things that you could go ahead and replace for peace of mind, and it won't break the bank. If you do replace them, I recommend using Spicer joints. That's all I run in my trucks.
Old Dec 26, 2015 | 08:19 AM
BBslider001
Hey Bill! Happy New Year to you! This is kind of what I figured. No brownish dust, but 2.5 years and 50k miles since I bought it make me question. I'll definitely do Spicer. Who sells them?
Old Dec 26, 2015 | 08:22 AM
ReBilld's Avatar
ReBilld
Check with Napa and see if they have or can get them. If not, you can order them from Drivetrain America.
Old Dec 26, 2015 | 08:44 AM
97-psd's Avatar
97-psd
You can pull the drive shaft and check them. Just drop the ends and manipulate the caps. If they are smooth put it back in.
That is probably the best way to make sure the needles are in good shape. You can do the "drive-to-reverse" check to see if it clunks, but the best way to check the condition is to drop an end.
As far as the greaseable or non greaseable I noticed the non seem to be better joints
Old Dec 26, 2015 | 08:47 AM
97-psd's Avatar
97-psd
Man, I type slow. No responses to 3 by the time I finish typing.
Old Dec 26, 2015 | 09:09 AM
Bob_T's Avatar
Bob_T
I'm considering the same thing. I've always been old school and liked grease-able u-joints but I'm getting convinced that Spicer non-greaseable joints are the way to go. The local driveline shop also told me that the non-greaseable joints last longer. The seals are superior to the greaseable seal design. I think Summit Racing also sells Spicer joints. The NAPA guy told me that the NAPA brand joints are Spicer but I don't know that for a fact.
Old Dec 26, 2015 | 09:16 AM
BBslider001
Thanks Bill...I'll check them out.
Thanks Ben! I have heard this as well and will go this route. Thanks for the info! I'll look at them when it quits raining and do the process. I love this forum.
Thanks Bob! I have heard the same about the non-greaseable. Plus it's one less thing for me to worry about with maintenance. I'll check Napa and see what they say. i might look online and see if I can see who makes their joints.
Old Dec 26, 2015 | 09:57 AM
madMatador78's Avatar
madMatador78
The last few spicers I have gotten were greaseable.
Old Dec 26, 2015 | 01:21 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I've got 70k miles on a set of non grease able joints. Still tight.
Old Dec 26, 2015 | 02:06 PM
mechmagcn's Avatar
mechmagcn
The last time I went to Napa for u-joints I'm glad I checked before leaving the store, they were clearly marked "made in China" on the joint. Went to my regular parts store, same thing on Precision brand joints. Ordered the Spicers, at least they're still "made in USA".
Old Dec 26, 2015 | 04:18 PM
BBslider001
That's what I like to hear
Old Dec 26, 2015 | 06:20 PM
427 fordman's Avatar
427 fordman
I put spicer greasables in mine. Nothing wrong with the non greasables, I just like the ones I got. I did all mine at about 145k so don't have many miles on them (17k), but they are in good shape.
Old Dec 28, 2015 | 01:10 PM
lee00's Avatar
lee00
I don't know if this is true or not....but some older mechanics once told me that the non greasables are stronger...
ie no weak points...solid vs having grease ports through out... makes some sense...
Old Dec 28, 2015 | 02:44 PM
pilgrimbizket's Avatar
pilgrimbizket
I talked to a very respectable 4x4 guy who swears by non greaseable. His theory was the components can and will become containmented
