Head gaskets
Old Dec 24, 2015 | 11:28 PM
Sherman Manley's Avatar
Sherman Manley
Head gaskets
Hello,
I have a 2005 excursion 4x4 v10.
193000 mi.
The degas tank was puking coolant. And smelled like exhuast.
New therm and w/p.
Did a compression test . Everything in the 160 to 180 range,
So I decided to just do the head gaskets. Have not pulled heads yet. But pretty close.
Should I do anything else while this deep. Am I on the right track? And finally is there a link on how to reset the timing after putting heads back on.
I am a little worried as I do not see very many posts on headgasket replacements of These engines
Old Dec 24, 2015 | 11:30 PM
Sherman Manley
I am just beyond this point. Valve covers off and exhuast manifolds off
Restlesswildman's Avatar
Restlesswildman
ARP studs if available!
Factory head gaskets!
Old Dec 24, 2015 | 11:32 PM
Sherman Manley
Dang it.
I just received a shipment of federal mogle gaskets and replacement bolts.
Would u recommend I send them back
Old Dec 25, 2015 | 01:49 AM
Greenscobie86's Avatar
Greenscobie86
So you have good compression? I asked for the numbers in your other thread. It could just be a intake manifold gasket leak, I am 98% positive that there is a water jacket that goes through the intake manifold. Could be getting water in that way? Have you done a leakdown test?
If you have good compression I wouldn't go pulling heads off of it just yet IMO...
Clogged heater core or some blockage in the front/rear heat(if your truck has rear A/C)?
Also should have mentioned this in another thread but a pressure test of the cooling system might have been a good idea before it was torn apart, hindsight is always 20/20...
Old Dec 25, 2015 | 09:49 AM
harley4jcs's Avatar
harley4jcs
I don't know how you could have those #'s & have a bad head gasket as well.
Old Dec 25, 2015 | 09:49 PM
Sherman Manley
Well my rear heat has been blowing cold for a while. I always thought it was a blend door and would get to it later. But I don't understand how that or a intake gasket can make the tank puke and smell like exhaust.
Old Dec 25, 2015 | 09:52 PM
Sherman Manley
I hope it's not a head gasket. That's 300 I cold put toward springs.
I did not do a leak down. I will not go any further until I do if that test is that important. I will research if I can still do it with the intake off . I hope so.
Old Feb 28, 2016 | 05:54 PM
Sherman Manley
Hey everyone. Been a little while. With winter and all. I got a warm day today and decided to pull a head. Here is what it looked like. Tell me what u think.
Carbonized
I could remove pinch fulls of carbon
Look at that bottom wall. Scuffed.
Old Feb 29, 2016 | 06:46 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
water pump for sure
Old Feb 29, 2016 | 08:21 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by Curt's05
water pump for sure
Wut ? Help us understand your diagnosis ?
Old Feb 29, 2016 | 08:25 AM
Greenscobie86
I don't know, but it "sort of" doesn't look like the walls of the gasket were breached?
Is that a crack or a piece of carbon on the 3rd photo down from the top? On the left cylinder?
Old Feb 29, 2016 | 08:58 AM
pirate4x4_camo
In the first pic, looks like a possible crack between the valves of that forward cylinder.
I haven't pulled a non race fuel head in years but I think that white crap is the result of the "clean burning" fuel additives used nowadays.
Old Feb 29, 2016 | 09:01 AM
pirate4x4_camo
Also in first pic.
Second cylinder , Possible crack from near spark plug hole to intake valve,
Old Feb 29, 2016 | 10:22 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Coolant leaking:contaminated /high miles it Couldn't be easier. ..
