I recently purchased a 1966 F100 with a 4 speed manual and 352 engine. I am trying to get it running for chasing parts while I complete the build on my 1972 F100. I have changed the plugs, points, plug wires, and other minor things. In preparing to check the timing I discovered there is not a timing mark. The pointer is there but not the timing mark. I s this a common thing or do I have an engine that has been modified? Any information will be greatly appreciated.
Thanks for the response, I cleaned the pulley but will make sure that I got all of the grease and rust off to bare metal. How well is the pulley marked? Are the grooves fairly deep or just etches? Also, where can I find directions for setting timing using vacuum if the marks are not there?
The marks are there, but are likely very faint. The vacuum gauge method of setting timing works great, though.
Connect to a source of (constant) manifold vacuum. With engine at idle (500-600 RPM) advance distributor clockwise until maximum vacuum indication, about 19" or 20" on a stock engine at sea level. Back off (counterclockwise) about 1" from that, and check for ping or pre-detonation on heavy acceleration. Back off a little more if necessary and/or for safety margin. There's much more to setting engine timing than this, but it will work in a pinch and is a lot easier to set correctly.
