2wd spindle
Old Dec 23, 2015 | 10:56 PM
Newtoford96's Avatar
Newtoford96
2wd spindle
Hello all, I need some help I have a 96 f250 2wd and my wheel bearings took a crap on me after removing old bearings I noticed a lot of scaring and the threads on my spindle are shot. I have searched and searched but apparently this spindle doesn't exist anywhere. I need help finding a new assembly
Old Dec 23, 2015 | 11:07 PM
ReBilld's Avatar
ReBilld
May have to try a junk yard.
Old Dec 23, 2015 | 11:44 PM
fordpride's Avatar
fordpride
There are brand new ones on eBay but they ain't cheap. 395.00 each. I just ordered one for a buddy.
Part#'s
Left
F5TZ3106A
Right
F5TZ3105a
Old Dec 30, 2015 | 07:03 PM
Newtoford96
Ok I found a used spindle. Everything is going good except that when I put a new outer bearing race in the hub I can turn it with my finger. I'm confident that it is the right size bearing race. My first thought is that my hub is messed up, or is this normal for this hub. I'm not sure
Old Dec 30, 2015 | 07:05 PM
Newtoford96
Here is a picture
Old Dec 30, 2015 | 07:35 PM
fordpride's Avatar
fordpride
It shouldn't move
Old Dec 30, 2015 | 07:40 PM
Newtoford96
That's what I figured
Old Dec 30, 2015 | 08:53 PM
tractoman's Avatar
tractoman
Where'd the hub come from? Did you only get the used spindle? Sometimes bearings come with different race sizes for the same bearing. I know you said it's correct but something isn't adding up.
Old Dec 30, 2015 | 09:05 PM
Newtoford96
The hub is original from my truck the spindle came off a different truck but the same year so infinite when the outer bearings failed it either messed up the bearing seat in the hub or the parts store gave me the wrong size bearing race
Old Dec 30, 2015 | 09:06 PM
Newtoford96
I cleaned the inside of the hub real good as well as the failed race and didn't see any signs of it spinning in place so I'm leaning more towards it just being the wrong size race
Old Dec 30, 2015 | 09:33 PM
tractoman's Avatar
tractoman
My vote is the parts store foul up. Bring the old one in next time.
Old Dec 31, 2015 | 06:19 AM
Bob_T's Avatar
Bob_T
Did the original race just fall out? Normally you have to knock them out from the back side with a punch. If the original was in the there tight and the replacement is loose, then yeah, I'd say it was a parts store foul up.
elwood9270
1997 - 2003 F150
Jan 18, 2014 09:14 AM
scurbiedog
1978 - 1996 Big Bronco
Aug 2, 2013 09:10 PM
law2212
Dec 7, 2011 04:25 PM
tseftons
Sep 13, 2010 08:54 PM
WesDaBest
Mar 31, 2008 11:40 AM
