one thing i tell every excursion owner that may not know. open your back barn doors. do they open only to a 90 degree angle? if not, theres a little clip that you can undo so they open all the way 180 degrees. makes loading stuff A LOT easier.
Yes, it looks like everything is factory stock on the rear suspension. Most of the stock EXs have chewed that front rubber snubber away by now, yours still looks pretty good, your Ex must have lead an easy life!
Nope, I took a pic of the passenger side because that's the one that wasn't trashed!. The driver's side is still there but pretty much useless, doesn't stand up straight and is half rotted.
So, are those snubbers worth replacing since it will be a while until I do the V/modded B spring swap? What are they called so that I can search for them?
They are called front suspension bumper(By Dorman anyways) and can be found on RockAuto.com for a song compared ot the OEM Motorcraft ones or aftermarket Energy Suspension ones.. Here is a pic of the new ones I installed recently.
Scoobs, I think the one that you are showing is the type that mounts with two bolts vs the one from the rear traction bar that mounts with just a single stud.
I don't have the proper name or part number for the traction bar snubbers, hopefully someone here does and can share it here. If you are going to be keeping the stock rear suspension for a while yet I think it may be a good idea to replace them with something. They do help to limit the amount of rotation of the rear axle upon acceleration.
These were my stock snubbers that I sent off to a fellow member here, unfortunately age and exposure to the elements must have weakened them as they disintegrated shortly after he installed them.
Yes Tom those are the front bumpers that are in my pic. I guess I misread which rebound bumpers/bumps stops/snubbers the OP was asking for. I don't think RockAuto had the rears in stock, never looked because the ones on my truck are still in decent shape.
I just noticed that in my picture of my old snubbers that the part number is still fairly readable, I wonder if between them and the OP's still intact one if we can piece together a part number to search with........
