snow
Old Aug 7, 2003 | 06:00 PM
Igor176's Avatar
Igor176
snow
I have a 2000 crew cab lwb single rear wheel 4x4 and I want to put a plow on it and ford says it is not recommended that it exceeds the gawr. The trucks an f-350 psd I see other crew cabs with plows, is it the diesel? because I've seen them too what adverse effects am I going to have? any insight to this would be great.
thanks.
Old Aug 7, 2003 | 06:13 PM
theologian's Avatar
theologian
snow
You could do with beefing up the front springs if you intend to hang a plow up front.
Theo
Old Aug 7, 2003 | 08:23 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
snow
The "X" code springs from the snow plow/max gvw package are available through the dealer. The part # is 1C3Z5310AF.
Old Aug 9, 2003 | 05:27 AM
Igor176's Avatar
Igor176
snow
Thanks I'm going to look into those springs
Old Aug 9, 2003 | 07:34 PM
believer45's Avatar
believer45
snow
The problem with plows on a PowerStroke is the weight of the engine, as was hinted at in your original post. The diesel weighs some 400 lbs more than a V-10 gas if I am not mistaken and the lino's share of that weight goes on the front axle.
That said, I have seen a few who plow with them and have no problems. Just be aware of warranty issues if you "overload" the front axle against Fords' warnings.
Dave / Believer45
jmconneely
Jan 19, 2013 05:18 PM
dalton1000
May 7, 2010 07:48 PM
taylorjs
Nov 20, 2006 07:52 PM
NovaKid69
Mar 14, 2006 07:26 AM
johnny 99
Oct 16, 2003 05:09 AM
