Sponsored by: Real Truck
plowing with crew cab
Old May 6, 2010 | 08:15 PM
dalton1000's Avatar
dalton1000
Just curious if anyone has a plow on a crew cab long bed , and if they had any issues with the lenghth . also what plow is recommended , and does anyone have experience with 8' western pro plow plus. by the way i have a 2010 f350 crew cab long bed v10 auto.
thasnks
Old May 6, 2010 | 08:27 PM
Firefighter 1406's Avatar
Firefighter 1406
My dad plows with a crew 6ft. bed, and it is pushing it big time with the size. We plow some apartments and you can barely back drag out of a parking spot without hitting the car behind. It can be done but you would be limited on what kind of jobs you would be able to get. If you have wide open lots you shouldn't have any problems. You have to think that you are adding another 4ft. in front of a already long truck. Hope that helps some. Western plows are nice, if you go with the pro plow you can always add wings if you want to make it bigger.
Old May 6, 2010 | 09:35 PM
dalton1000's Avatar
dalton1000
anyone else have expierience with western?
Old May 6, 2010 | 10:13 PM
ken kenmnedy's Avatar
ken kenmnedy
i am on my second western in 12 years ,(sold the first with the truck) easy to fiwhen they break) easy to get parts for and this ultramount is great, they say my plow is to small but i plow public schools and do a lot of walks around the bildg. close fit some times
Old May 6, 2010 | 10:29 PM
Pinky Demon's Avatar
Pinky Demon
I have a Western 7.6" inch poly on a UltraMount to UniMount conversion hitch. I plow with a Crew Cab Short bed V10 250. The truck is pretty big, but I manage. The leaf spring turning radius is extremely poor, so if you have a coil sprung front end, you are better off. That CC/LB you got will be like driving a semi when plowing. Good luck, hope you got large lots.
As for the plow, it runs like a raped ape. Only problem I had with it was a chain that snapped over a very large bump. But I bought a better one and off I went. I am replacing it this year with a Boss 9.2 VXT V Plow, but mainly because I need a larger plow with V capability, not because I had excessive problems with the Western. And, with the older Uni Westerns, you can keep rebuilding them forever and ever. They just last. All in all, a solid plow. And 8 ft is slightly larger than the width of the truck, perfect for plowing and transportation, which is another big factor.
Old May 6, 2010 | 11:06 PM
SteveH-CO's Avatar
SteveH-CO
I have a Western pro-plow dated 1984 on a 1983 GMC reg cab/long bed. Perfect truck length. I'd hate to plow with a crew cab or anything other than a standard cab. The Western plow is an incredible piece of machinery - very nicely engineered and durable as can be. I do add 300# of sandbags to the bed of the GMC to offset the front plow weight. I plow my private drive and road, but with the plow sticking out another 5' in front of the truck, it still makes for a long package. There are days I wish I had a fullsize Bronco/Blazer to have an even shorter rig.
Old May 7, 2010 | 08:05 AM
iron1951's Avatar
iron1951
I have an 04 f250 creww cab & long box. I don't plow professionally but the length is a handicap on my father's curved driveway. Either I cut the corners or I have to back up and go forward many times to clean the curves. I did the same driveway many many years ago with a 78 Jeep CJ. What a difference. Again size does matter but in this case the shorter the better.
BTW I am from Canada and have an 8 foot Artic plow. I thought 7 1/2 foot would be too narrow when angled.
Old May 7, 2010 | 09:03 AM
Firefighter 1406
7 1/2 ft plow will not cover the path of our trucks at full angle, 8ft barely does.
Old May 7, 2010 | 12:15 PM
sammy77's Avatar
sammy77
I have plowed with my 05 F350 CC 8ft box since new and it's a real PITA at times. You definetely don't wanna go smaller than 8ft plow because of the length of truck. It really depends on what you're plowing, lucky for me I have all bigger wide open lots. If thats not the case with you, look for a short box to make life easier.
Old May 7, 2010 | 07:48 PM
dalton1000's Avatar
dalton1000
anyone have install prices on western pro plow 8'
PJS29
Oct 25, 2017 10:47 AM
landscapeguy
Feb 24, 2017 10:57 PM
snelldawg
Oct 26, 2016 05:39 AM
marcs724
Aug 15, 2016 09:45 AM
taylorjs
Nov 20, 2006 07:52 PM
