Sponsored by: Auxito
Window motor
Old Dec 22, 2015 | 05:30 PM
racin's Avatar
racin
Window motor
Just had my 03 extended cab at the body shop to fix some rust under the interior part of the doors both sides so they had doors off the truck and had the door panels off, now after I got it back my passenger side window is slow to go up and down just in the middle part of the window, I mean I don't think the body shop would matter it's just probably my window motor goin out? How hard is it to replace?
Old Dec 22, 2015 | 08:04 PM
steve(ill)'s Avatar
steve(ill)
if it is slow just in one spot, maybe the track got bent or pinched ? If the window is always "weak", them maybe the motor, but they are normally a GO - no GO situation.
Crank the window up half way and spray some silicon spray on the window edge and inside the track... see if that helps.
Old Dec 22, 2015 | 08:06 PM
steve(ill)'s Avatar
steve(ill)
could also be a bend or crud in the track / rollers that run horizontal under the window and are powered by the motor.
Old Dec 23, 2015 | 09:05 PM
toby tough's Avatar
toby tough
I have to spray mine about every 2 months. Seems to help quite a bit.
Javier89F150
Jul 23, 2015 01:43 PM
kilika77
1997 - 2003 F150
Nov 12, 2005 09:21 PM
edub32
Mar 15, 2005 11:11 PM
shotgunner426
Oct 3, 2003 04:06 PM
