Turn signals
Old Dec 22, 2015 | 10:07 AM
Paul Stalcup's Avatar
Paul Stalcup
Turn signals
Are the turn signals supposed to work with the key off ? The truck is a 1976 F600 361CID .
Old Dec 22, 2015 | 10:55 AM
Filthy Beast's Avatar
Filthy Beast
Not that I'm aware of. 4 way flashers, yes, turn signals, nope. Could be a hacked ignition switch if they do.
Old Dec 22, 2015 | 12:51 PM
Paul Stalcup
Ok , I sure didn't think so. I have modified the ignition though here is what I have done I'm sure I'm getting some back feed from something I just need to know where to put the dioide! I have a MSD street fire ignition and a accel points eliminator in the distributor! Where should I put the dioide? If that's the right word. Let me put it this way what wire or wires do I put the filter in so the current will just run one way?
Old Dec 22, 2015 | 01:21 PM
Filthy Beast
Sorry, my friend..... I have zero knowledge of MSD, etc ignition stuff, not having played with them. DS I, DS II, HEI, points, etc...ok ,but not all this new fangled stuff. Is there any directions to help you? Diode icon is something like this -->, no? with the arrow pointing in the direction of current?
Sorry, again for the no help.......someone will be along who know this stuff, I'm sure.
Old Dec 23, 2015 | 07:21 AM
Paul Stalcup
Thanks Filthy Beast, I should have left it along I guess but it sure has helped the old motor pull the load, especially at low RPM where these kinds of trucks stay at, I'm sure it's pretty simple if I could just find my instruction sheet lol because MSD knew this would happen because they sent the dioide with the ignition box .
Old Dec 23, 2015 | 09:18 AM
hiball3985's Avatar
hiball3985
You might try posting this in the Electrical/wiring section rather then this engine section for more answers.
Old Dec 23, 2015 | 10:34 AM
yetiman38237's Avatar
yetiman38237
Is the diode for MSD or Accel? I would call or contact tech line for whichever one. I tried the Accel thing and finally put in trash and bought the Petronix unit.........Maybe you can have better luck with that setup. I tried taking the rotor off and it exploded in my hand.....guy at Accel said I should have pried it up with a screw driver.....lol. I told him I didn't want to rely on anything as fragile as a chicken egg in my distributor......
Old Dec 23, 2015 | 08:35 PM
Paul Stalcup
Lol very true with the accel rotor button, I have pulled it off a couple of times waiting for it to come apart! The diode came with the MSD street fire, the only thing that I wonder about is did the signals blink with the key off before I put this stuff on , and I don't mean they come on when I turn the key off ! They will work with the key off but I do have to work the turn signal arm on the steering wheel before they come on , its not like they just come on when I shut the key off !
Old Dec 23, 2015 | 08:38 PM
Paul Stalcup
I will when I find that section, I haven't seen it yet!
Old Dec 26, 2015 | 07:57 PM
85e150's Avatar
85e150
Google "msd street fire instructions" and find this and a host of others:
https://www.msdignition.com/uploaded...ions1/5520.pdf
Paul Stalcup
Electrical Systems/Wiring
Dec 28, 2015 07:55 AM
abbeville84
May 30, 2007 09:18 PM
pmibach
1978 - 1996 Big Bronco
Jan 31, 2006 08:37 PM
nj2003F150Buff
1997 - 2003 F150
Mar 28, 2005 10:23 AM
The Fife
Apr 8, 2004 01:09 AM
