Cam Problems?
Old Dec 21, 2015 | 11:57 AM
newr's Avatar
newr
Cam Problems?
Hello all
My '05 Nav has developed a sound that I thought sounded like and exhaust leak. It is not there on cold start but develops as the engine hits operating temperature. I stopped by the local stealership today and the service manager told me that he thinks it is components in the Cam Timing system, probably the chain followers. Then without blinking an eye he says that they they to pull the engine to work on the back side of the engine.
Really? At 75K miles they have to pull the engine to work on cams?
Anybody have any similar experience?
Thanks in advance.
Old Dec 21, 2015 | 05:05 PM
rla2005's Avatar
rla2005
Yes, plenty of us have had issues with cam phasers and chain tensioners. As I have found out too many folks dismissed a ticking noise as issues with the above but turns out be a lesser problem.
FWIW the phasers and tensioners are on the front of the motor.
Mt ticking noise on my recently new to me '05 Navigator was a spark plug had loosened itself over 150k miles. Very similar symptoms as yours, but a very simple fix.
Not to say this is your issue, but I would not go back to the stealership until you do some research and some detective work for yourself. Plenty of info in this forum on cam phasers, tensioners, broken plugs, etc. here.
Old Dec 22, 2015 | 01:56 PM
newr's Avatar
newr
As I Expected
Thanks for the reply RLA. This closer to what I expected.
The stop at the stealership was started by my wife because she wanted a "Factory" second fob and key. After $133 for the programmed fob I asked the service manager about the ticking noise and got the above response. Standing there on the service floor it was all I could do to not tell him what I really think.
Better manners did prevail but I won't soon forget that conversation.
Old Dec 22, 2015 | 03:01 PM
Skauber's Avatar
Skauber
I've never heard of anyone having to pull the engine and work on the BACK of it in order to replace the timing components and cam phasers. Sure, it's not a small task, but it is a in-vehicle job, no need to pull the engine.
shadetreevanguy
Mar 1, 2018 08:11 PM
Brack1
2004 - 2008 F150
18
Apr 5, 2016 12:02 PM
F250_05SD
May 5, 2011 06:35 AM
ukjones
2004 - 2008 F150
20
Sep 28, 2007 05:58 AM
fordman19762003
2004 - 2008 F150
Jul 20, 2006 02:22 PM
