Cluster swap?
Old Dec 19, 2015 | 11:49 PM
PRIMERED79 SHORT BED's Avatar
Cluster swap?
Some months back I found a instrument cluster out of a 93-94 f150 and it had the tach.
So I grabbed it up and installed it into my 92 f150, and all gauges and light seem to work but one.
My light for 4h wont light but will light in 4L and last time I messed with it the bulb was good, so I played it off as a mis wiring deal.
But now I'd like to fix it, did I use the wrong cluster?
Which wire from the harness is for the 4H light?
And if the light isnt getting power, but have power from the 4h wire can I jump a wire over to the light plug?
Before the cluster swap everything worked great.
Old Dec 20, 2015 | 02:15 AM
pnp522's Avatar
pnp522
If I remember right 92-93 are the same and 94-95 are the same. When I changed the wiring harness in my 93 it was replaced with one from a 95 and things were in different places on the clusters.
Old Dec 20, 2015 | 08:39 AM
Do you know if the printed circuit broad changed through the yrs?
Old Dec 24, 2015 | 07:41 PM
Well just to finish this thread I'll update it.
Some months ago I was having speedo issues so got a salvage cluster and did some swapping, dont remember what I did exactly, but took the bezel off and noticed my 4wd light bulb was gone, so installed a new bulb and all of a sudden the lights both work now.
Easy fix
Old Dec 24, 2015 | 09:11 PM
78 PEB's Avatar
78 PEB
I like when it's that easy!!!
77f100guy
Jan 18, 2010 08:04 AM
ReAX
Oct 5, 2006 06:43 PM
LARIAT 85
Sep 23, 2006 12:51 AM
dsh82
May 8, 2003 08:00 AM
