Sponsored by: Real Truck
Cluster diagnostic
Old Oct 3, 2006 | 05:24 PM
ReAX's Avatar
ReAX
Cluster diagnostic
Would someone with a 2002 F250 check thier cluster diagnostics for me?
I have run throught the diag, but when it is supposed to light all of the bulbs, the batt light fails to illuminate. I just want to see if anyone else's doesn't.
Old Oct 4, 2006 | 03:50 PM
ReAX's Avatar
ReAX
If not, then does anyone know the routing of the field, grn/red wire from the alternator to the interior and modules it passes through?
Old Oct 4, 2006 | 06:28 PM
rwilimo's Avatar
rwilimo
The battery light should be on as soon as you turn the key on without starting the engine. The cluster test's do not affect the light is anyway (it will be on)
I'm not looking at a schematic but as far as I know the wire run's straight from the cluster to the alternator, there are harness connectors in between but there should be no modules involved.
Are you having some kind of problem? If you are then post back and maybe we can get to the bottom of it.
Old Oct 4, 2006 | 06:31 PM
ReAX's Avatar
ReAX
Yep, not charging and the light will not activate.
Old Oct 4, 2006 | 06:33 PM
ReAX's Avatar
ReAX
By the way, I have replaced the Alt, VSM and Cluster. Ford programmed it all, and still no charge , no light and the door ajar is on (checked backwards and forwards, it has some goofy issue.)
Are you looking at an alt wiring diagram? I am hoping there is a plug somewhere between the cluster/GEM and the alt I can wiggle.
Old Oct 4, 2006 | 06:37 PM
rwilimo's Avatar
rwilimo
Unplug the field connector from the alternator and ground the green/red wire and see if the light comes on. If it does the alternator is not working, if it does not then the wire is faulty or you have no power to the bulb. I have seen the harness get damaged on a few Excursion's around the battery, you might start looking there.
Old Oct 4, 2006 | 06:48 PM
ReAX's Avatar
ReAX
So both wires run over to the battery area, I imagine the field wire splits off at the last Tee before the ylw wire turns to fusabe links. I'll give it a try, thanks for the input.
Old Oct 4, 2006 | 07:03 PM
ReAX's Avatar
ReAX
The looming looks fine, but I have to pull the alt to get the pig tail out and pull the battery to get to harness. My optima is not leaking, what kind of damage have you seen? I will try again tomorrow when I have light and tools out.
The field wire does hold voltage for a while after the key goes off. KOEoff both wires in the pig tail have .03v short of battery voltage. It took 24hr for most of the voltage to die off on the field coil this weekend, I had just shy of .5v. Shouldn't the light be on with the KOEoff? The power should be connecting to gound to created a magnetic field and turning the light on. So why (other than blown bulbs which has been eliminated) would the light never turn on?
Old Oct 5, 2006 | 05:49 AM
rwilimo's Avatar
rwilimo
With the key on, you should have battery voltage at the Orange/ (sometimes Yellow/) wire. You should have a lower voltage (3-8volts) on the green/ wire as it pass's through the bulb. A failed regulator in the alternator can cause the light malfunction as well as a damaged wire. Check out the harness and let us know.
Old Oct 5, 2006 | 08:14 AM
ReAX's Avatar
ReAX
All three wires have battery voltage within .08v. I'll pull it apart this afternoon and look.
Old Oct 5, 2006 | 04:28 PM
ReAX's Avatar
ReAX
Shorting the grn/red to gound does light the battery lamp, I then unshorted and the lamp went out.
Something to add though, I also disconected the ground to my warn winch. It has a solenoid to disconnect the hot lead, but with out the ground connected I have some funny stuff going on with the keep alive curcuit.
Update, never mind about the keep alive one door was open. However on my way home, the cluster said I had 13.6v. I am going to put the new alt back on and leave the winch disconnected to see what happens.
Old Oct 5, 2006 | 06:43 PM
ReAX's Avatar
ReAX
Update.
Old alt will charge with all accy off, so it must have a blown diode. New alt is somehow dead where it will not light the lamp. The winch thing hasn't panned out, I put it back on after verifing the alt was putting out and everything still works. I am almost happy.
Traildust
May 18, 2014 03:48 PM
Tech Man
Mar 26, 2014 09:33 PM
FordFinatic157
Oct 5, 2013 09:35 PM
RIKIL
24
Mar 9, 2013 03:50 PM
AllaboutMPG
Jun 19, 2012 11:15 AM
