Oil consumption...
Old Dec 19, 2015 | 02:43 PM
bryanlindborg600's Avatar
bryanlindborg600
Oil consumption...
Been awhile guys, but I need some input..I got an oil consumption problem. I get a fairly obvious blue smoke out the tail pipe most of the time.. I replaced my injector o rings not too long ago, maybe 7-10k ago.. I did that because I believed it to be the problem initially, and the first 1k it seemed to keep the oil level just perfect after that I've been using about a gallon every 1500-2k probably more miles then that but too much usage if you ask me... Could I have possibly nicked an o-ring on install and it didn't manifest till a later time.? Last I checked my dowmpipe didn't have any signs of oil and I know it's a dumby test but my oil cap doesn't move off the valve cover when upside down.. Need some ideas its driving me nuts.. Truck has about 200k on it..
Thanks guys!
Old Dec 19, 2015 | 04:30 PM
z31freakify's Avatar
z31freakify
There might be that possibility, but also the turbo oil seal can also let go from the compressor side. The cheap option is to do a compression test to see if its the engine itself, but check that turbo really good.
Old Dec 19, 2015 | 06:17 PM
427 fordman's Avatar
427 fordman
Do you notice any oil in the fuel filter housing? Is it black in there?
Old Dec 19, 2015 | 06:45 PM
bryanlindborg600
Will do! So pulling the intake boot inspecting for oil there is where I should look?
Thanks!
bryanlindborg600
I'll take a look in there tomorrow!
Old Dec 19, 2015 | 06:49 PM
z31freakify
Do as fordman says first, I always forget about leaks
Old Dec 19, 2015 | 09:21 PM
fordpride's Avatar
fordpride
Only a few places it can go.
In the fuel (via injector orings)
In the cylinders (via internal injector orings )
On the ground
Through the turbo
In the coolant (oil cooler)
Burning it (bad rings)
Old Dec 19, 2015 | 09:30 PM
coreyallan01's Avatar
coreyallan01
If your seeing it in the fuel filter I would guess It may have a long crank when hot? No?
Old Dec 19, 2015 | 09:34 PM
fordpride's Avatar
fordpride
If it was bad enough yes
Old Dec 20, 2015 | 09:00 PM
bryanlindborg600
Well sadly no black on the fuel filter or in the housing... I really don't wanna have a bad engine..but its not looking good... I guess at this point I'm hoping turbo...?
Old Dec 21, 2015 | 11:05 AM
427 fordman
I'd pull the dp off then and have a look. I highly doubt you have a bad motor.
robbie7045
May 1, 2015 09:45 PM
gungho351
20
Sep 27, 2011 08:46 AM
CheaperJeeper
13
Aug 5, 2008 12:40 AM
Twinkie111
May 25, 2008 01:41 PM
DD1684
May 15, 2005 10:20 PM
