Hinge Pin Bushings
Old Dec 18, 2015 | 04:32 PM
Gicknordon's Avatar
Gicknordon
Hinge Pin Bushings
So I am in the middle of replacing the hinge pins on my drivers door. The new pins fit snug in the door side of the hinge, but are pretty loose on the cab side of the hinge. Is this normal, or should it be tighter? It is much better that the originals, but seems a little looser then it should be. My dad suggested getting some bushings made to go on the cab side of the hinge, but if it's not needed i will just continue as is.
Old Dec 18, 2015 | 04:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
They can't be tight in both pieces of the hinge, or you couldn't open the door. Depends how sloppy the fit in the stationary part is. It is nice to be able to get oil in there (would be even nicer to have a grease fitting). It would be tough to put in a bushing that exactly aligned with the door pin holes.
Old Dec 18, 2015 | 05:12 PM
raytasch's Avatar
raytasch
Believe Nothing
Somewhere in my mind I remember something about there being two different diameter hinge pins.
Old Dec 18, 2015 | 11:19 PM
harleymsn's Avatar
harleymsn
Midwest Early Ford sells a SS oversized pin (page 90 new catalog)
Old Dec 19, 2015 | 08:03 AM
rdemilt's Avatar
rdemilt
If the bushings were worn excessively and the holes are now oversized, the holes can be welded and re drilled to the correct size for the bushing OD. Without good tight hinges, aligning the door is pretty much impossible.
winginit
May 13, 2015 09:13 AM
E100PU
Mar 11, 2009 10:14 PM
pjckm
Aug 17, 2006 09:52 PM
barebackjake
Oct 22, 2005 11:07 AM
blrman1962
1978 - 1996 Big Bronco
Feb 28, 2005 04:37 PM
