Clutch bleeding
Old Dec 18, 2015 | 01:49 PM
ItsAFord55's Avatar
ItsAFord55
Clutch bleeding
I'm trying to bleed the clutch on my '84 but there dosent seem to be a bleeder valve anywhere , any ideas ?
Old Dec 18, 2015 | 04:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There should be an Allen set screw in front of where the line attaches. (on top)
Open it as far as you can swing the wrench against the line.
The little hole on the end of the slave (facing the front of the truck) is the bleed port.
Old Dec 27, 2015 | 06:58 PM
reamer's Avatar
reamer
ArdWrknTrk, were is the location of the screw? by the master cylinder? or on the slave?
Thanks
Old Dec 27, 2015 | 07:11 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
With a truck that has external slave the bleeder screw is in front of where the line attaches to the slave cylinder.
If you have a metal slave like mine there's a bleed nipple just like a brake caliper.
If you have the plastic slave there is an Allen set screw in the top face of the slave and a little bleed hole on the front facing forward.
nacra88
May 15, 2016 06:06 PM
storchmj
May 7, 2013 03:49 PM
86straightsix
Nov 22, 2011 02:33 PM
rnelson664
Oct 4, 2008 02:44 AM
Diesel Fiend
Aug 23, 2008 06:50 PM
